Clutch pedal positio
Discussion in 'General Ranchero Help' started by Dark Side Tom, Mar 5, 2019.
  1. Dark Side Tom
    Dark Side Tom In Second Gear BRONZE MEMBER
    Removed and repaired my clutch pedal bumper on my '64 Ranchero.
    It bolts into the swing pedal assembly with a short carriage bolt.
    My pedal is now just right and sits nearly level with the brake pedal pad.
    The bumper pad is riveted into the bracket. I dremelled off the rivet head and then bolted on a hard plastic block using the rivet hole.
    The frame hole for the carriage bolt is a rectangular hole that allows some up/down adjustment.
    Really a PIA to cram yourself in there to remove and replace the bumper bracket. Find a skinny 130 pound friend to do it for you!
    DST
    beerbelly and TestDummy like this.
    I'm 6'6" and 425...I just lay across the seat and work upside-down!
