coolant to use for newly rebuilt 460
Discussion in 'General Ranchero Help' started by rancheromac, Aug 23, 2024.
  1. rancheromac
    rancheromac In Third Gear
    best anti freeze/coolant for a added aluminum radiator. all listed as color? thanks
  2. pmrphil
    Just use the green stuff, no need to try and get fancy, it's still an iron headed 460, right? Even aluminum heads would still use the green antifreeze.
    aquartlow likes this.
  3. 1965 Ranchero 66G
    If in doubt, there is a universal mix that covers all and will protect the newer seals and gaskets.
    Buds 67 likes this.
  4. Clark
    I use Walmart antifreeze in my newly rebuilt 460 - same as always (and I'm cheap).
    I did get a new 3-row copper radiator from Summit Racing. I'm not a fan of aluminum radiators for this '75 Ranchero.
  5. Jeff B
    If a first start, try distilled water. Run it to check for leaks and flush out oil and assembly boogers. When you are happy with everything, drop the water and fill with green stuff.
    beerbelly likes this.
