Different color transmission modulators
Discussion in 'General Ranchero Help' started by Gregory Cummings, May 16, 2019.
  1. Gregory Cummings
    Oceanside, CA
    ok Chero fans, So I went to autozone to just check on what size hose I needed for the manifold vacuum to transmission modulator I needed. first of all I did'nt know which transmission I had C4 or C6 AOD for my '79 351/400M ranchero. He brought up several modulators with different color codes. Well now, what the heck. red, green yellow or orange strip ? ? ?. What do the color coded modulators mean. Different shift perameters I thought. so I'm guessing what size hose and what striped color coded modulator, any thoughts would be cool.
  2. rancheromac
    rancheromac In Third Gear
    probably have an FMX, not sure of color stripe much except I heard black stripe is for strip use ? anybody else know?
    First, look at the door tag. 'X' means FMX, and as long as its the original trans, it's likely the modulator is also original. Just shinny underneath with a rag, carefully clean it enough to see the stripe, which goes around the body. Just so you know, FMX's have a bolt-on bellhousing.
  4. Carl Steinbarger
    Carl Steinbarger In Second Gear
    Dayton, Ohio
    I do know for a c4 the modulator should have a green stripe...
  5. Doc76251
    Doc76251 In Fourth Gear
    Virginia Beach, VA
    Did a green stripe on my 77 FMX, I haven't come off the original setting but it shifts much better and I no longer have trans fluid in my vacuum lines. I may decide to firm it up while I am underneath it looking for an errant fluid leak. As I understand it you turn the little adjusting screw inside where the vacuum line attaches CW to firm, CCW to loosen. I know it should be done with a pressure regulator etc. but I'll settle for a seat of the pants feel. Also as I understand it NO MORE than 2.5 turns from stock in either direction. Make sure you find and keep the "rod" that may or may not come out when you pull the original part, you have to put it back in, it is the actuator rod. There are those that adjust the overall length of the rod but I will let you research that on your own because I don't recall the details.
    Cheers,
    Doc
    Edit to add: you NEED a VERY THIN wrench to get that hummer in and locked down, mine came out by hand but I ended up using a table leg adjusting wrench that I had (stamped non hardened sheet metal) to get it tight.
    Carl Steinbarger likes this.
  6. andrewok1
    DOC,
    had no idea you are a transmission Medic also:D
  7. Doc76251
    Virginia Beach, VA
    Oh shit no dude! Anything that happens aft of the flex plate an forward of the drive shaft is PFM. I took me 45 hrs of Google to figure out a vacuum modulator and even that was a crap shoot. I'm just passing on what I learned. I'ma buy a T-56 turn key and bolt it in but I still need to figure out the clutch pedal as a 77 never had one. Now if you need a total hip or knee I can walk you through that step by step.
    Cheers,
    Doc
    As a technician myself, PFM is all too real. And no, 'PFM' does not stand for "Pacific Fast Mail."
  9. Gregory Cummings
    Oceanside, CA
    forgive my ignorance but what is FMX.
  10. Gregory Cummings
    Oceanside, CA
  11. ForistellFord
    Beautiful Foristell Missouri
