Disc Harrow
Discussion in 'Non-Automotive Stuff' started by Hillbilly, Feb 20, 2020.
  1. Hillbilly
    Dennis / Andy, this is really close to the disc Dennis is getting. In the pic it is adjusted straight across to lessen how much it cuts up the ground while moving it to a field. To set it to a more aggressive cut you move one lever then pop the tractor clutch . It will move the cutters to a sharper angle. To go back to the towing position you move the same lever and just back up until everything is straight across. To make it cut deeper you add weight to the rock boxes on the tops of the gangs. Engines, old diesel heads, big rocks, whatever you can find. You will have to experiment to find out how much weight and cutting angle your tractor can deal with. The Ford is probably limited to pulling the disc at a regular walking pace but that depends on your soil too. disc harrow 2.jpg
    andrewok1 likes this.
  2. TestDummy
    Lisa Harrow
  3. Hillbilly
    No doubt she would be a lot more fun.
    andrewok1 and TestDummy like this.
  4. As Is '66
    Southwest Georgia
    I gotta wife I need the disc Harrow Sean...
    But she can come visit
  5. TestDummy
    She's like 88 years old, and all yours.
  6. ForistellFord
    You're half right. Even at 88 she has better sense than that.
