Distributer hold down bolt. Can’t access.
Discussion in 'General Ranchero Help' started by HappyFlappy, Oct 4, 2020.
  1. HappyFlappy
    HappyFlappy In First Gear
    I have a 73 ranchero with a 351cj. I did points and I need to fix timing. My engine has air conditioning and it’s in the way. Is there a way to do timing without removing the compressor?
  2. Hillbilly
    Go to a decent auto parts house, they will have or can get what is called a "Distributor Wrench ". It will be bent in such a fashion needed to reach under the distributor to get at that hold down bolt. Not expensive and saves a lot of cursing.
    DZG likes this.
  3. LSChero
    Old K-D I have had for 40 years!
    Lincolnut likes this.
    Everyone who diddles with timing has one!
  5. TestDummy
    I have swivel sockets.
    MaxInValrico likes this.
  6. Mycuzinvinny
    Mycuzinvinny In First Gear SILVER MEMBER
    I need to buy one also. Is it a standard size or is each distributor hold down bolt different? 1976 351M with factory air.
    Ford is 1/2", GM is 9/16" for SAE engines. It's why you get two ends.
  8. Mycuzinvinny
    Thanks
    That's why we're all here! You're quite welcome!
  10. Chigger1
    Chigger1 In First Gear
    Made mine out of an old extra 1/2 wrench. Heated it with a torch then just make your bend.
    Mycuzinvinny, pmrphil and The Wrench like this.
