distributor stuck!
Discussion in 'Ranchero Tech Help' started by Dan the ranchero man, Nov 9, 2020.
  1. handy_andy_cv64
    Ooh, I forgot about a Lady Slipper. If placed right and done right, especially if you have a second person attempting to turn it back and forth, it might just loosen enough for making the adjustment.
  2. Dan the ranchero man
    Thanks again for all your suggestions! I have lots of ideas going into this on Saturday afternoon (Have to work now in AM) But I will get this sucker to move. Just need to retard timing about 10 degrees. This is just a bone stock 76 460 engine so having the timing at 30 BTDC is just plain impractical for normal driving. Hot starts are beating up the starter and it advances so much once running at cruising it just feels like it is surging. Disconnected the vacuum advance and that made it a whole lot better but still not right.
    Wait...30 degrees at idle? WOW. You have three advances on timing--initial setting (14 degrees at 650 in your case), mechanical advance and vacuum advance. If, with the vacuum disconnected, you're still reading 30 degrees, that would tell me that the cetrifugal advance mechanism is stuck in the advanced position, and whoever touched it last severely advanced it to compensate for it. I hate to be the bearer of bad news, but you need a replacement dizzy anyway, or that one needs rebuilding.
  4. pmrphil
    Andy, I fail to understand how you came to that conclusion. It's fairly easy to check and see if the mechanical advance is working, just rev it up. Otherwise the timing would NEVER change, seeing that he already disconnected the vacuum advance.
    The Wrench likes this.
  5. Dan the ranchero man
    Yes you are right. The timing still advances with the vacuum disconnected.
    Okay, that is true, I didn't think. I had assumed he would have already done that, as he knew where the base timing was. So, shame on me for making an ass out of me and me.
  7. Dan the ranchero man
    No worries I know you are trying to help.
  8. aquartlow
    Hey Dan, maybe some heat with a propane torch to get the block warm/hot around the distributor then hit the distributor body with some carb or brake cleaner, the cleaners will be quite cool/cold coming out of the spray straw. Might be enough "shock" temperature-wise to allow the block to loosen it's grip on the distributor.
  9. Dan the ranchero man
    If it involves fire I am in! I put that in mybag of tricks that will be used to loosen this thing up!
  10. Boiler92
    Indiana
    Be very careful if you plan to heat it up.
    I investigate fires for a living. I see almost everything as either an ignition source, fuel or oxidant. Seen a lot of bad outcomes.
  11. Hillbilly
    Ok. Got a dumb question for you Boiler 92. What is your opinion on carrying Halotron extinguishers for vehicle fires ? I already know to get the biggest lung full of air I can before setting one off and to have an escape route ready.
  12. Dan the ranchero man
    Trust me I take playing with fire while doing things like this very seriously. I will have an extinguisher handy. In this case would be my last resort. Going to try other things first. I love a good fire but not a car b que!
    Hillbilly and Boiler92 like this.
  13. pmrphil
    We luv ya anyway, big boy :p
    Hillbilly likes this.
  14. Boiler92
    Indiana
    Sorry, but I'm a forensic electrical engineer. I study the aftermath. Not an expert on extinguishing agents.
    Sounds like a plan, and don't forget to breathe out as you exit the carbecue.
  16. handy_andy_cv64
    Any news yet?
  17. pmrphil
    No, he's working on it Saturday afternoon
  18. Dan the ranchero man
    Yep, late Saturday after noon and Sunday morning.
  19. Dan the ranchero man
    Ok folks here we go........FAILED :(:(:(:(! tried everything that was suggested and that thing will not move unless one gets very aggressive. I just need to rotate this thing back about 1/4 inch. I had a 3 ft crow bar on it in a real nice spot. I thought this was the ticket! NOT!!! the smaller round trunk of the dizzy was twisting so much I thought it was going to break off. At this point I will leave it alone until springtime when all the other cars are available to me and I know the weather will not be an issue. Unless someone has a trick up their sleeve that is where it stands for now.
  20. Boiler92
    Indiana
    Air chisel/hammer in very short bursts?
