engine mount 72 429
Discussion in 'Ranchero Parts for Sale LINKS' started by Giska1, May 6, 2012.
  1. Giska1
  2. Rods N Restos
    Rods N Restos In Fourth Gear
    South Jersey
    no photos
    429-460 motor mounts are 3 pice and consist of block plates,heat shield and Isolator mounts that attach to the crossmember
    here are the used ones I refurbished for my car
  3. Giska1
    I know I have 3 sets but someone was looking for them so I thought I would let them check it out:D
  4. Rods N Restos
    South Jersey
    from what I was told they are not available from parts suppliers anymore
    I know for sure you can't get the block plates but not 100% on the isolator brackets that mount the crossmember.
    if they can't find good used most are buying the Crites mounts
  5. bmf
    bmf In Third Gear
    Chico, Ca
  6. Rods N Restos
    South Jersey
    anybody use those from Summit?
    they look like the modified the mount to access the bolt location but not sure if they are correct to bolt up to the crossmember on a Ranchero/Gran Torino
  7. ribald1
  8. 5.0 Chero
  9. Rods N Restos
    South Jersey
    that was what I was thinking
  10. Torkair
    Torkair In Maximum Overdrive
    Tucson, Az
    an't we use the mounts from a full sized car such as a lincoln/thunderbird?
  11. 5.0 Chero
    Lincoln mark and Thunderbird are not considered full size
  12. bmf
    bmf In Third Gear
    Chico, Ca
    2 pages of ford, lincoln,mercury
    Engine Swap
    No
    Universal
    No
    Make
    FORD
    Model
    GALAXIE 500
    Submodel
    BASE
    Beginning Year
    1969
    Ending Year
    1973
    Engine Type
    V8
    Liter
    7.0
    CID
    429
    Engine Size
    7.0L/429
    Engine Family
    Ford big block 385 Series
    Drivetrain
    RWD
    Application Notes
    Fits the front right side.
    Engine Swap
    No
    Universal
    No
    Make
    FORD
    Model
    GRAN TORINO
    Submodel
    BASE
    Beginning Year
    1972
    Ending Year
    1973
    Engine Type
    V8
    Liter
    7.0
    CID
    429
    Engine Size
    7.0L/429
    Engine Family
    Drivetrain
    RWD
    Application Notes
    Fits the front left side.
    Engine Swap
    No
  13. 5.0 Chero
    Will be listing a set on Ebay today they are from 74/6 but as a set can be used on 72/3
  14. rancheromac
    rancheromac In Third Gear
    cant find site,use to be a converson kit ??
    anybody know ??
  15. Brian Loula
    Brian Loula In Fourth Gear
    Worth,Il.
    Try www.rockauto.com , look under ford thunderbird or lincoln MKIV 72-76; lincoln MKV 77-79.
