Firewall connectors - 1963 Ranchero
Discussion in 'General Ranchero Help' started by Tygrz, Nov 27, 2013.
  1. Tygrz
    Tygrz In Second Gear
    Having pretty mean electrical problems - want to disconnect firewall connectors and trace.
    Firewall connectors covered in sprayed rust prevention goop. How do they come apart? Is there a tab to squeeze or something? On the sides or top and bottom?
    Thanks in advance....
  2. psb
    psb In Second Gear
    Bump for a good question...
  3. Bryan59EC
    Bryan59EC In Overdrive
    San Antonio, Texas
    These can be a pain----but they just pull apart.
    7-8 pins in each connector and over the course of 50 years
    they will take a pretyy good set.
    I have yanked on some of these thing with big force
    and they will refuse to separate.
    Patience and gentle wiggling should get them apart, but it may take some time to do it
    without further damage to the harness.
    No bolts or pins are holding them together---just friction.
    I have recently made new wiring harnesses for my 65
    and incorporated a GM fuseblock and firewall disconnect.
    Not a lot of room to do this in the stock location.
    Has to be accurately located to avoid hood hinge contact,
    and the driver side vent needs to come off for access
    to the fusebox (if mounted close tot he disconnect)
  4. woodscavenger
    woodscavenger In Second Gear
    Boise, ID
    Any pics of your firewall wiring upgrade?
  5. Bryan59EC
    San Antonio, Texas
    I have a couple of pics somewhere I need to find of mocking it up.
    Cabin wiring harness actually got hung under the dash and hooked up to the firewall today.
    I'll get a few more pics within the week---after I get the car into some good light
