front end suspension kit
Discussion in 'Ranchero Tech Help' started by 72 gt 429, Sep 5, 2015.
  1. 72 gt 429
    72 gt 429 In Second Gear
    Best front all rubber suspension kit for 72 ranchero - found a pst kit - looks like almost everything needed for both sides complete , have to look at parts list to see if it has everything needed . Any other kits anyone know of that may have full kits ? Thanks
  2. ribald1
    I used the PST kit on my 72.
    The only issue I had was the ball joints as mine is an early 72.
  3. 72 gt 429
    / you do the rubber or polygraphite ? If poly any squeak on them ? Guess I would call and give them the date on the car the door tag says 3/72 / thanks
    Call them, that is an early model.
    I used the poly, but with my 521 solid roller engine with full length headers and the entire cab covered with Dynamat, the front end could squeak like a cat with it's tail caught under a rocking chair and I might not hear it.
  5. 72 gt 429
    LOL - no sneakin in the back door late at night either park down the street . ha
  6. 5.0 Chero
    Pst is great kit yes 72 has early and late differences in the kits Poly is great not squeaks even after 8 years of daily driving
  7. 72 gt 429
    Thanks for info will check tomorrow on parts .
  8. HuevosRanchero
    yes make sure if you go poly (i did and no squeaks after years) get the BLACK....it is impregnated with lube..the red is NOT.
  9. azex2001
    azex2001 In First Gear
    That's funny right there.
  10. RancheroRandy
    So red poly isn't impregnated? I need to replace the bushings on my leaf springs and was thinkin' red would look kinda nice...?
  11. HuevosRanchero
    unless things have changed, when I bought my bushes the website for P-S-T said that the black was impregnated with i think graphite or some such and the red was not.
  12. MaxInValrico
    I believe that is still the case.
    I didn't go with the PST kit and just sourced all the parts from Moog, however the sway bar bushings I bought from Energy Suspension which are poly that have a zirx fitting on them so you can grease them.
