fuel filler neck relocation
Discussion in 'General Ranchero Help' started by Mikey likes it, May 14, 2024.
  1. Mikey likes it
    Mikey likes it In Second Gear
    On my 62 Ranchero I want to move the gas filler to inside the bed. I see several routes, but Im sure somebody has best results and advice. I can weld ok, but not sure about how to slice it, or whether reroute using rubber is best. Ideas please
  2. scout44
    scout44 In First Gear
    Sonoma County California
    I have seen seveal Rancheros over time with the gas filler located to the inside bed. I have considered this myself. Putting gas in the truck now is difficult and always a struggle . Still working on the best way to address this
  3. RancheroRandy
    Make sure you have a good vent (above the filler neck inlet) to the gas tank...THAT will solve most of the angst when filling as long as you don't try and go too fast....I have done that on all the Rancheros that I have owned (4) and it solves the problem with the stupid gas tanks Ford "repurposed" for their use....
  4. Mikey likes it
    So do you use a 2 way vent at the end of the line? I have the original open steel vent line that snakes up and down the rear fender, it releases gas smell
  5. RancheroRandy
    Well, since I took this pic I have relocated the vent higher up like the arrow shows...
  6. Mikey likes it
    where did you source yours? I see various motorcycle gas tank vents, but I want to be sure. thx
  7. RancheroRandy
    https://www.tanksinc.com/
  8. DJ Clinton
    DJ Clinton In Fourth Gear GOLD MEMBER
    Mesquite, NV
    I used the same vent, but mounted it inside the bed instead of in the fenderwell. Keeps the vapor from entering the cab.
  9. RancheroRandy
    The space where fumes can waft into the cab through the quarter panels I stuffed with foam rubber as a barrier. I works pretty good and the only time I notice any gas smell is when my tank is pretty full and going around right-hand curves "vigorously"... ;)
  10. Mikey likes it
    much obliged fellas, I ordered the valve from tanksinc.
