Fullsize/Lincoln brake caliper brackets
Discussion in 'Ranchero Parts For Sale' started by aquartlow, Jan 23, 2021.
  1. aquartlow
    Found a set of full-size/Lincoln brake caliper mounting brackets that allows larger diameter rotors to be installed while reusing your '73-'79 Ranchero calipers/brake pads. Brackets come with mounting bolts. $100 for the pair plus shipping.
  2. andrewok1
    Todd
    i will buy those from you
    ANDY
  3. aquartlow
    10-4 Andy. Whenever you want them, just let me know. Thank you
  4. aquartlow
  5. Hillbilly
    Not running under Andy, just curious. 1978 Mk Lincoln, would those be the same ? Got one that has four wheel disc brakes. I know the Lincoln has a larger lug pattern but if the entire spindle and brake assembly was used along with the entire rear axel assembly, is it possible those would bolt up under a 72 thru 79 Ranchero ? My Lincoln suffered a rusted roof under the vinyl top that resulted in the floor pan rusting beyond redemption. Parts car now for when a solid Ranchero turns up.
  6. aquartlow
    IIRC, the whole spindle assembly will bolt up to '72-'79 Ranchero upper/lower control arms(a bit of a difference in the early UCA bushings), ball joints, tie rods, brake calipers and brake hoses are the same.
  7. 5.0 Chero
    Pete the Lincoln caliper bracket will bolt on to 74 up spindles yes.
  8. Hillbilly
    Thanks guys, knowing that makes the swap even easier.
