Gaylord bed cover
Discussion in 'Ranchero Parts For Sale' started by ribald1, Oct 12, 2018.
  1. ribald1
    I have 72+ gaylord bed cover that I can't use due to shortening my bed by 8-1/2" to increase cab space.
    Had a deal to trade for some door panels, but that fell through.
    If anyone is interested, PM me.
    Otherwise I will place on Ebay.
  2. 5.0 Chero
    come on shorten the cover
    HuevosRanchero and TestDummy like this.
  3. ribald1
    I looked long and hard at that option as I like having a cover.
    The problem is that there is no reasonable way to marry two pieces of plywood end to end with a strength that approximates a continuous sheet.
    I even considered using it to make a mold, cutting the mold down and making one from scratch. A serious undertaking for a one off item. Anyway, with this tiny 2000 sqft shop I don't have room to swing a cat, much less dedicate a couple of hundred square feet to a fiberglass project.
  4. Kiwirancher
    Kiwirancher In Second Gear
    Gisborne , New Zealand .
    Hi ribald1 , are there any pictures of your Ranchero on here? I am intrigued to see what an extended cab Ranchero looks like.
    Denis.
  5. ribald1
    Yeah, there is a thread called extended cab ranchero
  6. aquartlow
    Would taking it to a body shop be an option, let them cut/shorten it and have all the mess/debris involved. Just a thought. I built my own using 1" square tubing as a frame, but it fits inside the bed trim with an internal "gutter" system that takes 99% of any water to the tailgate/bed opening, works really well. Andy (Andrewok1) and Dennis (As is '66) can verify it's fit/function. I can also stand on the installed bed cover no problem and I'm almost 3 Benjamin's, man I need to walk more and eat less.
  7. andrewok1
  8. ribald1
    A body shop would not be able to deal with the plywood issue, the only real solution to that is a frame built underneath, and at that point I would do as you did and just make one. I have all the same equipment as a body shop, I do a lot of it. The cab extension I did is not even noticed by people who see the car for the first time. I have to tell them it was done.
  9. Kiwirancher
    Checked out the thread , thanks andrewok1 A lot of impressive work done there . I presume it is finished and on the road ribald1. To do something like that here would be possible but would take a lot of money and time getting it certified.
    Denis.
  10. ribald1
    Not finished, life got in the way.
    It is done except for paint and the headliner.
  11. RANCHEROROB
    Pueblo de Los Angeles, Aztlan
    Use the front 4 ft. as is and cut a straight line across the cover about 12 18 inches from the tailgate, remove the correct amount then mate the two pieces together with a stainless piano hinge or other type hidden hinge.
    You would have a small trunk lid that you can open up to un latch cover or open the tailgate
  12. ribald1
    I don't have a tailgate. The back area is the 2 20 gallon fuel cells and the two batteries. Almost a foot of the front of the bed is taken up by the speaker compartment. The cover needs to be stout as if I carry anything, it will be on the cover.
    The real issue with your idea is sealing the fiberglass and plywood at the cut and hinge areas.
    Thanks for the idea, I hadn't considered that possibility.
  13. TestDummy
    In other words, do it right, or don't do it. Bravo.
  14. rat-racing
    rat-racing In Second Gear
    Pensacola, FL.
    Do you still have the Gaylord bed cover? Will it fit a 76 Ranchero?
