headers for 72 Ranchero wanted
Discussion in 'Ranchero Tech Help' started by GRUMANIA, Jan 8, 2019.
  1. GRUMANIA
    GRUMANIA In Third Gear
    Germany
    Hi,
    I have a 72 ranchero. It had once a turbo supercharger with homemade headers and I want a new, complete exhaust system.The car is in the shop at the moment and they ordered a set of headers finding out that these do not fit as the gearbox is too wide ( its an FMX gearbox )
    It seams as if the combination Cleveland/ FMX gearbox does not allow to install standard aftermarket headers.
    Has anyone an idea where I can find help ?
    Thanks in advance !
    Ilja
  2. GRUMANIA
    Germany
    These are the Flowtech 12118 FLT which do not fit between gearbox ( FMX ) FT12118FLT.jpg and steering column
  3. uk ranchero
    uk ranchero In Second Gear
    not much help. i have headers on my 72 [cleveland/aode] they are fitted as bought no clearance issue. unfortunately i got them new/old stock and no box so i have no idea who made them. so i know you will find them and please let use know as mine are rusty
  4. aquartlow
    Not sure if this will help or be helpful, but many years ago I put a set of Hedman headers on a 4x4 I had and the driver's side header didn't clear the driveshaft to the front end, the muffler shop owner took a "rosebud" tipped torch and heated the tubes until it could be "manipulated" enough for the necessary clearance. I never had an issue with those headers even after this modification.
  5. Jimbob
    I have Hedman 88320 headers on a Cleveland/FMX. They clear, but sit real close to the starter (heat issues are a concern). I seem to recall after doing some research at the time that the FMX is a similar size to a C4 so i went for it.
    http://forum.grantorinosport.org/hedman-headers_topic16009.html
    Have a read of this ^^ about 6 posts down
  6. GRUMANIA
    Germany
    Thanks for your help.Meanwhile I found a set of COYOTE headers on Ebay. ( picture ) Has anyone seen / Used these before ?
    They seem to be slim compared to the Flowtech.The seller is asking for 600$,........
    Thanks
  7. GRUMANIA
    Germany
    Bought the COYOTE headers - these fit
    Thanks for your help !
    Ilja
    That's great to hear. So please, make sure you take and post photos, please?
  9. GRUMANIA
    Germany
      File size:
      140.2 KB
      7
      File size:
      158 KB
      7
    1Shovelhead likes this.
  10. GRUMANIA
    Germany
    As you can see, its a very tight fit but the mechanic said that these headers are very precisely made and fit from the first moment, without any adjustment, bending or so.
    Think these headers were a good investment.
    Ilja
    I see your Cleveland also has a chrome oil pan. My Windsor got one only because, at the time, I could not find a steel pan, only the chrome one. At least it was $55 at the time.
  12. GRUMANIA
    Germany
    the original oil pan was totally damaged, because the car was too low.Front Springs and oil pan changed now. 72 Ranchy low.jpg
  13. handy_andy_cv64
    Wow, that is a lot of rake.
  14. GRUMANIA
    Germany
    Good look , but the oil pan doesnt like it
  15. aquartlow
    Headers are almost always a tight fit for our intermediates, especially the driver's side, I believe they design/build the DS header based on an intermediate model that has a Saginaw power steering gear which is a bit smaller in size as compared to a Ford steering gear(you have the Ford steering gear). Your headers look good, there may be a bit of "self clearancing" with the steering's pitman and idler arms when turning lock to lock, nothing out of the ordinary though and shouldn't hurt anything.
  16. 1Shovelhead
    1Shovelhead In First Gear
    Any idea where I could find a set? I have the same setup, 351C-w-FMX. I can't seem to find anything
  17. beerbelly
    I see you have the proper "tools" for a photo shoot!
  18. GRUMANIA
    Germany
    Hi Shovelhead,
    try to phone Sven in germany 0049 1733284901. He sold me the headers for 500,- Euros.He seems to have a lot of headers for Ford engines
    Ilja
  19. parts4me
    parts4me In Maximum Overdrive
    Nebraska
    What about shorty headers? Anyone use those?
  20. GRUMANIA
    Germany
    Shorty headers might solve the problem, but full length headers provide more HP.......
