Heater core replacement- Jeez!
Discussion in 'Lounge' started by beerbelly, Mar 22, 2022.
  1. beerbelly
    Rock Auto has me confused; they call for a 7 lb. cap for a '65 289 Ranchero, but 13 lb. caps for a Falcon and a Mustang, same year and engine. I can't find any spec for cap pressure in my manual, but I went with the odds when I replaced the 16 lb. Cold Case radiator cap with a 13 lb. version.
  2. Hillbilly
    Got to agree about GM and shoddy evaporator cores. Out of the five 1996 Buick Roadmaster wagons I have owned, had to replace all five evaporator cores. Went back with NAPA brand cores and have had no recuring problems. Heater cores haven't leaked but they all had to be back flushed to remove casting sand. Almost as annoying as having to deal with their crappy Opti-Spark distributors.
    Y'all already know how I feel about Opti-Spark. But casting sand, in a heater core? That's as unforgivable as finding it in a block or cylinder head.
  4. Hillbilly
    Common problem on the LT-1 engine GM cars.
    The only time I found casting sand in anything was a Jeep 4.0L that had a leaky rear freeze plug. I think I scooped and flushed about 2 dry pounds sand. Any amount is bad, but that much? That's quite unforgivable.
  6. beerbelly
    The new aluminum core arrived today; it looks good and fits perfectly. So now I'm trying to convince my body to re-install the heater.:(
    If anyone needs one, it's a Scott Drake C5DZ-18476-AL that I got from Summit.
  7. beerbelly
    All done, new antifreeze and a test drive- no leaks!:D
  8. pmrphil
    By chance did you check and see where it's manufactured? Scott Drake stuff used to be the best, but Holley bought them out. :eek:
  9. beerbelly
    Oh, I think you can guess....and the previous one came from Mexico. But I sure wasn't gonna pay for an NOS one.
  10. pmrphil
    Oh, hell, NO. :eek: I'd be putting in the same thing as you!!
    beerbelly likes this.
  11. 1979 RANCHERO GT
    My wonder is the intake and return appear to be coming out of the same tank. Hopefully they are separated or I don't think much coolant is going to go through the core.
    Nearly all cores are that way; the velocity of the water pushes it through the core. If the tubes get blocked, there's still coolant flow.
