The control valve is intended to block the inlet to the heater core...which is fed by the supply side of the heater circuit. The fitting on the engine block is the supply/pressure side of the circuit, so from your pictures, it appears you have the valve on the return. The downside of having the valve on the return side is possibly a little bit of heat making it's way into the heater core. The valve should have a flow direction indicator...I think that's more important to get right as it may impede the function of the valve if it's backwards.
The water lines on my F150 were swapped, and there was constantly warm/hot air coming through the vents, even with the control turned all the way toward "blue".
Thank you for this valuable information. Maybe the person who installed that heater water valve thought the hose coming from the water pump was the supply side... But even if the heater water valve is in the wrong hose, or doesn't exist at all, at least in the Ranchero when the cold/hot lever is pulled to the cold position, the wire in the cold/hot lever closes the hatch in the air duct so that the air being blown in doesn't go through the heater core. In my car, it doesn't get hot when the cold/hot control is in the "cold" position, even though the heater water valve is apparently in the wrong hose, and I do get hot air in the car when I put the cold/hot control in the hot position. Probably the hot water in the heater core warms the air a little, which is not needed in a summer car. I'll change the heater water valve to another hose because "Basstrix"s arguments sound reasonable.
So the valve is now in the wrong hose (return line) and in the wrong direction, because now the coolant is coming to the valve from the heater core.
