Help figuring out what car this motor actually came in
Discussion in 'General Ranchero Help' started by lefty2111, Jun 18, 2024.
  1. lefty2111
    lefty2111 In First Gear
    Looks like I've got a block that was cast in 1980? Definitely not original as it should've came with a 351w according to the title. Cast number EA03 D3C. Intake cast numbers-3AE-9425-HB. Heads- D80E 80(50?) AB. Serial Number on block EX620731. Also has the number 2080 stamped in the front of block behind timing cover. 20 over 80 in a little square. Just trying to get as much info as I can.
  2. LSChero
    Block casting on rt side above starter.Perhaps EOAE-D3C? 80-84 302..
  3. pmrphil
    Yeah, that's a 302 intake, not a 351
  4. lefty2111
    Very possible I wrote it down wrong while I was on my back under the car
  5. lefty2111
    I know. One of the reasons I know it's not original.
  6. burninbush
    I guessing you have a normal 302 engine. To my surprise, those '351' heads were also installed on some 302 motors. If you have removed the distributor, the 302 came with a 5/16 hex drive shaft; think that ID's it as a 302.
  7. pmrphil
    Nope, the 302's all had 1/4" hex drive, as did most FE's - 351W,C,M, and 429-460 all had 5/16.
    The intake part number gave it away - 302 intake won't fit on a 351.
    And Ford in their infinite wisdom, used the same part number for some 302 and 351 heads, but the head bolt holes were 7/16 on the 302, while they were 1/2" on the 351W.
  8. lefty2111
    Yea, it's undoubtedly a 302. I've measured the bore and stroke. My main concern right now is that I'm going to replace the harmonic balancer with the wrong one, since it changed in 81. What I took off is the 50oz but I have no idea if it's actually correct. That's why I'm hoping to find out what it actually came in.
  9. pmrphil
    Look at the block - if it has the dipstick hole in the block down by the oil pan rail, it's 50 oz. , unless some genius replaced the crank, damper, and flexplate. Fairly unlikely.
    If the engine is out, look at the rear seal - a one piece seal is also the tell tale of a 50 oz. engine.
    RancheroRandy and lefty2111 like this.
  10. lefty2111
    Engine is still in, just with the top end off in my backyard. I agree though, I don't think someone would change damper, flexplate and crank but I certainly wouldn't put it past someone to just install the wrong damper. But I didn't know that about the dip stick location. 50 oz should be correct then.
  11. burninbush
    Woops, right idea, wrong numbers. Prmphil got it correct.
