Hey ford ranchero folks
Discussion in 'General Automotive Questions' started by lovemy78GT, Jul 12, 2017.
  1. lovemy78GT
    lovemy78GT In Second Gear
    Russellville Arkansas USA
    I have 78 ranchero. trying to locate what color wire is ground for fuel sending unit in tank. Fuel gauge works fine setting still but when you start moving gauge goes to empty. I'm hoping it's ground and not sending unit.
  2. Cindy
    Bay Area>>>>Gold Country, CA
    I had my sending unit changed out awhile back, but even now when I don't run Cochise for awhile, his fuel gauge shouts "screw you!" and quits workin until he calms down.
  3. FordR500GT
    FordR500GT In Maximum Overdrive
    Chaparral, NM
    The one on my '74 is yellow w/ black stripe. On the '72 and '73, it is just black
  4. lovemy78GT
    thank you. I'll take a look and see. Did research and found yellow/white is hot.
  5. 1978GT
    Pos is Yellow with White tracer, ground is Black.
    rancheromac likes this.
  6. lovemy78GT
    Thank you for schematics. Looked the world over LOL. Question? both wires run to plug on sending unit. Can I take black wire and splice into it and run frame ground?
    Yes, you can; if you do, a serrated-head bolt or a star washer with the bolt helps make a better ground.
  8. lovemy78GT
    Thanks.....glad it won't effect the gauge.
    BUT, (and this is a big one like mine), you have to ensure the frame grounding is also solid at the battery, or it will cause problems.
  10. rancheromac
    rancheromac In Third Gear
    what year is the schematic for ? where can I find these and more schematics for a 79 ranchero ? thanks
    I went to the city library and copied a full set (actually, two full sets about 10 years apart) from one of their Chilton professional wiring diagram books, and the diagrams are Ford diagrams, which was a plus. If yours doesn't have anything like that in the reference section, let me know, and I could print and mail a set to you.
