Hi-I'm a newbe here
Discussion in 'Announcements' started by Kenneth Wissmann, Oct 19, 2020.
  1. Kenneth Wissmann
    Kenneth Wissmann In First Gear
    I just purchased a 67 ranchero-390-4spd. This car has an electronic distributor with 4 wires to it but no identifying name or numbers. It is wired to a square black coil with a bright blue heat sink around it. My question is do I need to use the resistor wire to the coil or can I go full 12 volts to it.
    Feeding 12v from the battery it runs fine.
    Thanks for your input
    Jeff B likes this.
  2. Jeff B
    Hi Ken. Post a picture of the distributor, someone will likely jump in to help.
  3. Kenneth Wissmann
    20201019_160812.jpg Thanks-some pix
    I don't know if this will work but it's not letting me post more pictures ,says file too large.
    I'll keep working on it
