High beams cause the dash lights to go out
Discussion in 'Ranchero Tech Help' started by dadcohn, Jul 22, 2019.
  1. dadcohn
    dadcohn In First Gear
    Danville, CA
    I finally got the dash lights to work (except the high beam indicator) on my 64 after replacing the constant Voltage Regulator. Unfortunately that didn’t fix my fuel gauge problem. When I press the high beam switch on the floor the dash lights go out but return if I press it again. Any thoughts on that guys? Thanks!
    This is a weird one (what else is new?). The dimmer only switches between the headlights and has zip to do with interior illumination. Even if the high beam indicator was incorrectly wired, it should not cause the lighting to turn off. Blow a fuse, I could see that; it happened to me when a friend wired a radio for me way back when. After that, I did my own radios. Anyway, the upshot was that power connected to power blew a fuse. But in this instance, the lights come back on, on low beam.
  3. 5.0 Chero
    sounds like the lights are grounding through the high beam light
  4. pmrphil
    Bingo !!
  5. 62restomod
    62restomod In Third Gear BRONZE MEMBER
    Yea, definitely check grounds at the headlights
  6. 5.0 Chero
    he needs to make sure the lighting circuit instrument cluster housing is grounded
    Freestyle Don likes this.
  7. dadcohn
    Danville, CA
    Don’t the screws that hold the instrument cluster ground it?
