High test and lead substitute?
Discussion in 'General Ranchero Help' started by Raindog, Jul 12, 2019.
  1. Raindog
    Raindog In Second Gear
    Getting ready to put the 65 with 200 c.u. 6 cyl. back on the road, I'm thinking high test gas with a lead substitute. Opinions, comments, warnings?... I think that's the combo I used years ago before I parked it. lead.JPG
  2. TestDummy
    Your engine a high compression straight-6? I'd maybe add the lead (but probably wouldn't) and would run 87-89 in it.
    I don't remember the inlines having a high compression from the factory, but did you mod yours to bring up the CR?
  4. Hillbilly
    A 65 didn't come with hardened valve seats so yes, continue using the lead substitute. If you just putted around the neighborhood you possibly could sneak by but in the off chance you had to run it up to highway speeds for any length of time I would rather err on the caution side and run the lead substitute.
  5. Raindog
    Thanks all. I don't know about high compression, it's just the stock 200 six. I'll carry on with the substitute...
    Good plan. High-test was for engines with higher compression ratios. You'd be wasting your money with 92 octane. But, keep your engine clean, run it up and down the freeway every once in a while, you should be able to use any grade down to 85 octane with little or no trouble.
