hole saw ?
Discussion in 'General Automotive Questions' started by Clark, May 3, 2018.
  1. Clark
    Am making a rear bumper for my 2002 Ford Ranger using a piece of 6" channel iron - maybe 1/8" thick. I need to cut/drill two 1 3/8" (35 mm) holes for the original Ford license plate light fixtures.
    Drill bits that size run about $110 but I don't possess a drill press anyway (and I think it probably stupid to try that with a 1/2" drill).
    Can I cut those with a bi-metal hole saw (about $9.00 each) or a carbide hole saw (about $17 each)?
  2. ribald1
    Yes, the hole saw is the proper tool.
    Keep it oiled and stop if it smokes. If you don't overheat a hole saw, even a bi-metal one will make a dozen or more holes in 1/8 steel.
  3. Steve 74gtQ
    Steve 74gtQ In Overdrive
    Medford Oregon
    Even pressure and more on the slow side.
    Much faster then a drill bit.
  4. TestDummy
    Hole saws are awesome.
  5. ForistellFord
    Beautiful Foristell Missouri
    You'd really like a reciprocating saw then!
  6. TestDummy
    You try cutting a 1 1/8" hole in steel plating with a reciprocating saw. We'll wait. And it better be round, too.
  7. ForistellFord
    That isn't what they are used for. So, saws excite you but you know nothing about them?
  8. TestDummy
    You're werid.
  9. ForistellFord
    Not Cosby werid though.
  10. TestDummy
    To be clear, Clark got his answer regarding hole saws, thrice. So why not banter?
  11. Jeff B
  12. beerbelly
    If there was a Uni-bit that could cut that large of a hole, I imagine it would be a pretty spendy piece.
  13. Jeff B
    You could be right, BB. The good news is you own it (like a hole saw) and they are pretty handy for other projects. Looks like 1 3/8" is as big as the Irwins go, but there are other brands and prices out there too.
  14. TestDummy
    We use the hell out of Uni-bit's at work, mostly the smaller ones, and usually to get through sheet metal. The big boy (13/16-1 1/8") is over $80. For bigger holes we use hole saws.
  15. ribald1
    I have them up to 2". The big ones are expensive though and I wouldn't use one on something that thick. I use the big unibits on thin metal and plastics and the like that won't hold a pilot bit properly.
    You also have to turn the big one slowly.
  16. Clark
    Alright, used a 1 3/8" Lenox bi-metal hole saw. Kept it submerged with oil - easy after I got a grove started. Worked extremely well at least on this standard construction 6" channel iron. Thanks guys.
  17. TestDummy
    Next time try a plasma cutter.
  18. Jeff B
    Thanks for posting the result. I guessed (wrong) that a hole saw would not hold up.
