How badly do you want Manual Shift?
Discussion in 'Ranchero Parts for Sale LINKS' started by HuevosRanchero, Sep 2, 2009.
  1. HuevosRanchero
  2. Dan the ranchero man
    Not That Bad!!!
    This is what happens when you smoke crack and post items for sale on Ebay. I can see $400 for those no way over 1K!!! Sorry!
  3. Denny
    Well, it never hurts to ask for it because there's a sucker born every minute. It also wouldn't hurt to make an offer though. One of our moderators who lives on the west coast has probably already offered him a whole lot less for it.;)
  4. 75 Squire
    I could see 1K if he had the trans and the steering coulmn with the rest of the stuff.
  5. HuevosRanchero
    ditto!!:D:D
  6. 5.0 Chero
    Hey there is only one mod on the west coast.............:cool:
  7. Dan the ranchero man
    Of course it would be worth it then because now it is a "conversion kit" and not JUST a set of pedals.
  8. Denny
    Yes, I knew that.......and he's been known to make a buck or two on eBay.:D
  9. 5.0 Chero
    Well he dose try.....;)
  10. Torkair
    Torkair In Maximum Overdrive
    Tucson, Az
    Wow that is flipping rediculous! Im just a mount away from having everything needed for my stick shift conversion, I think its the frame mount that i need or maby the block mount, im not sure which. I even have the clutch fork rod which is definately missing from that auction.
  11. ramair428cjxr7
    ramair428cjxr7 In Overdrive
    conversion
    well that makes me feel better about the 400.00 i spent on the pedal assembly hurst shifter tranny hump and all brackets needed to install to frame i need the smaller lower return spring can i use the auto column if i install a collar from a 69 cougar
  12. CJ Guy
    CJ Guy In Maximum Overdrive
    Space, The final Frontier
    The ad was pulled, what was it? I should add up all I have in mine just waiting to be installed, most NOS stuff even the pedal assembly is NOS, correct rebuilt 4sp/bellhousing/new hurst shifter, everything I need...
    Nope not gonna add it up...:D
  13. Torkair
    Tucson, Az
    I think it was just pedal hangers. I've since gotten rid of the z bar in favor of going with a hydraulic clutch setup though. Also still looking into getting some reproduction floor humps made using a really nice one that my buddy found in a junk yard as a template, damn finders/keepers rule... At least I got the center console out of the same car...
