Idle oil pressure
Discussion in 'The Stable' started by 74Rancherito, Dec 26, 2015.
  1. 74Rancherito
    74Rancherito In Fourth Gear
    South Central, Cali
    My girl has been running fine, better than fine, like a bat outta hell.
    But my question is, is 50 ok at idle?
  2. Dan the ranchero man
    YES! The rule of thumb is 10 psi for every 1000 RPM. So if you are @ 50 PSI and assuming your idle is around 650-800... YEA your in great shape! :D Take care Dan
  3. ribald1
    As stated above, idle oil pressure is not real important.
    If you have that pressure when standing on it at 4000rpm with a hot engine, you are in good shape.
  4. 74Rancherito
    South Central, Cali
    Thanks guys.....
