Issues with fuel gauge accuracy
Discussion in 'General Ranchero Help' started by Michael Talbott, Nov 23, 2024.
  1. Michael Talbott
    Michael Talbott In First Gear
    Hi my name is Mike. I have a '77 ranchero GT
    And I need help with a fuel gauge discrepancy
    So originally at a full tank my fuel gauge would read 3/4 full. I decided that a new sending unit and float should fix that.
    Well my new one after install at full tank read about 1/2. So I assumed the new one was bad so I got a replacement. Well now the 2nd new one at full reads about a 1/4
    Not quite sure what's going on. Was hoping someone else either has had this issue that they solved or had an idea what it could be
  2. Jeff B.
    Anacortes, WA
    New tank floats have to be calibrated by bending the rod up or down so the gauge reads correctly. Did you do that before installing it in the tank?
    andrewok1 likes this.
  3. Michael Talbott
    I was not aware of that. Thank you.
  4. andrewok1
    Drain the tank...
    Pull float
    Don't mash the rubber gasket till u have it adjusted to where it reads empty
    Try it wires hooked up and just metal locking ring..
    Don't need to go crazy bending the rod
    Hold rod bend by hand..
    Hold rod like u would if you where going to snap a pencil ✏️
    I usually pour 3 gallons in the tank..then adjust the float so it reads Just on (E)
    That way you have 3 gallons on E for Reserve.,.and I are set
    Being as u don't need to drop thank...
    Good luck with that
    BlackBeauty and Jeff B. like this.
