lan to wifi conversion
Discussion in 'Car and Home Audio' started by Clark, Jul 25, 2019.
  1. Clark
    Anyone know how to adapt a Sony smart DVD player with lan connection for wifi connection instead?
  2. ForistellFord
    If there is no WiFi adapter available, maybe you could use a WiFi extender that has an ethernet port on it?
  3. Clark
    Ah yes. Exactly what I need and not very expensive either.
  4. ForistellFord
    Just make sure that if you don't actually need an extender in that area for coverage, set the transmit power to the lowest setting, and use a different SSID than your regular one. Overlap would potentially cause issues with your other clients. Lowering the transmit power would not weaken the connection between the router and the extender, it will just lessen crosstalk on the current network.
  5. 1965 Ranchero 66G
    All Greek to me, would an extender work from my house to my home shop 150' away so I could get WiFi in the shop. ?
  6. ForistellFord
    Not one you'd get at Best Buy...
  7. Basstrix
    I think you could if you used one of those focusing antennas....they focus the signal off the antenna, concentrating the beam and giving quite a bit more range. You can find templates online that use card stock and aluminum foil.
  8. Basstrix
  9. ForistellFord
    Ah, the old Pringle Yagi.
    Basstrix likes this.
  10. ForistellFord
