My 1972 Q Code
Discussion in 'Ranchero Pics' started by john777, Mar 16, 2009.
  1. *RD*
    *RD* In Maximum Overdrive
    Upstate New York
    aussie 2bbl heads I want!!!
  2. john777
    john777 In Overdrive
    Latest update
    I cleaned the engine all day, did some engine bay painting. Using POR 15 semi gloss, a little to shine for me, too bad they didn't have any flat...
    The 4300D is being shipped out tomorrow from Pony Carbs. I had to take the hood off to get into the engine, those 72 hoods dont raise up very high...
  3. john777
    before and after
    Almost done with the engine bay/undercoating:
    Went a little crazy with the undercoat and paint...
  4. john777
  5. 72GTVA
    Lookin' good!
  6. Hillbilly
    Hey John 777, you're a good man doing good work on that Ranchero. You'll enjoy that ride. What's the story on the "Hawaii 5-0" Mercury in the background ?
  7. HuevosRanchero
    nice work 7's amazing transformation
  8. john777
    The seller says it has a 429 in it with BOSS heads, 3500$. I did not look under the hood.
  9. john777
    more #'s
    Anyone want to decode for me?
    Under the starter:
    D2AE-CA
    2B2
    Intake:
    D1ZE 9425 BB
    2A15
    Heads:
    1K19
    Rear end on a tag:
    WEC-AH 1MD
    3.25-9-843A
    Rear end stamped:
    DIF3
  10. 72GTVA
    D2AE-CA 1972 351 Cleveland Block Casting Code
    2B2 - Cast on 1972 February 2
    D1ZE 9425 BB 1971 Ford 4V Intake Design, Ford Spreadbore
    2A15 - Cast on 1972 January 15
    1K19 - Cast on 1971 November 19
    WEC-AH 1MD 9 Inch Conventional Axle 4 Pinion, 28 spline Axle
    3.25-9-843A 3.25:1 Ratio 9 Inch Ring Gear
    D1F3 - Assembled 1971 June 3 if that is a date code, that does not appear to be correct though based on the axle production call out.
  11. john777
    I guess we can call this a numbers matching car...
    Thanks for you help, I am still waiting on the carb to arrive.
  12. john777
    latest....
    Not hooked up yet...
    :D
  13. trikar
    trikar In Maximum Overdrive
    San Bernardino Mountains
    Good job of cleaning up the engine and engine bay:cool:
  14. john777
    car is running!
    The 4300D carb was installed and the new mufflers were installed. Magnaflow 14325's. Not impressed with the sound at all. :confused: I have flowmaster 50's on my other car and dynomaxes on the other, both sound way better...
    I'm probably going to get them replaced, any ideas? I need a little more sound but not glass packs!
    2 1/4 inch H pipes.
    The car runs great, a bit more power, but having difficulties on the launch, not a whole lot of rubber being laid down.
    I am still happy with the overall results. I will have some fine tuning done tomorrow and will bring the beast home on wednesday!:D
  15. 72GTVA
    You should not expect a lot of rubber with the rear end you have.
  16. *RD*
    Upstate New York
    Yeah, there is probably only like 3.00s in there or at the most 3.25s in there.
  17. john777
    It has 3.25's
  18. *RD*
    Upstate New York
    I noticed that in the previous post, and I edited it earlier. None the less that is going to be a sick car when you are done.
  19. sarah
    Its looking good John... keep up the good work
  20. john777
    Today in SF
