My 69 Ram Air 428CJ
  1. PonyExpressRider
    Found a picture from the Car Show
  2. eqshadimar
    eqshadimar In Overdrive
    Austin - TX
    Keep plugging away! It is good to see that you are making progress.
    Laters,
    Jeff
  3. PonyExpressRider
    Update....
    Had to do a partial teardown of the front end. Removed the coil springs, to gain access to the upper A and the grease fittings, they were to tight to the Tower walls to get a grease gun on them. Got that problem fixed, the springs back in, shocks, and hubs are installed.
    THEN! Doing some casual contemplation, picked up my Marti report, just scanning the information again like I have more then a few times before, and BAM! All of a sudden staring right at me. POWER STEERING! There it was right on the Window Sticker. I have never known this car with power steering. So I grab my date code book, run out to the garage, clean the date tag off, compare it to the book, and start crying! Marti says the car was sold in June of 1969. The Manufacturing Tag on the Manual Steering Box, 9H, '69 August. OH CRAP!
    So Apparently, my Uncle, in the search for more horsepower. Replaced the Power Steering with Manual Steering to accommodate the change of the factory exhaust manifolds for Headers. SO! The search is on for a power steering box that will match up with the 5/13/1969 factory bucked date.
    I may have already gotten lucky. A friend of mine has a 68 Mustang which used the same Pump and Gear box. Subtle differences in the linkage, but he is willing to let me have it. So, if the numbers are late 68 (8I-L), I could be a happy camper. If not, I will be on hold for a while.
    If you don't mind my asking, why would you want power steering?
  5. PonyExpressRider
    Beyond it came on the car? I have pretty much decided, with input from many, that the car is too special to do anything but go back to what came off the assembly line.
    How special is it? To date, I am only aware of two '69 "R" code cars, with auto's, that are still matching numbers complete. Mine and another that is posted within this site.
    Going to try and find out more specifics about how many are actually left. But I am getting the feeling that the number of "matching number complete" is going to be very small. Based on what I know already, I will be surprised if the total number of registered 69 "R" codes is more then half of the number built (183). It may be time to start the Barn searches.
    andrewok1 and TestDummy like this.
  6. ribald1
    I didn't know the 69 had disc brakes, my bad.
  7. PonyExpressRider
    NP ribald, Power Disk Brakes option is listed on the window sticker right under the Power Steering. Since you put it that way, does that mean manual steering would most likely have had front drum brakes?
  8. ribald1
    I thought the discs were an upgrade you did as I didn't know they were an option in 69.
  9. PonyExpressRider
    Hi all... This will get put in the parts wanted also. Need a Power Steering Center Link, I may be able to get this through Rock Auto, etc. I also need a late 68 (last 3 months), early 69 (A, B, C) power steering gear box. I have a late 67 power steering gear box off of a 68 Mustang, and a late 69 Manual steering Gear/w center link for possible trade.
  10. davis
    davis In Maximum Overdrive
    Whittier, CA
  11. PonyExpressRider
  12. PonyExpressRider
    Hey All... just checking in... still kicking. Football season and Hunting Season almost done, so will be getting back at it. Trying to decide whether to get the motor rebuilt now or put my available funds to the Body and paint... still need to pull the rear end and get it cleaned up and checked out. Then can start putting stuff back on the underside. Gas Tank, brake lines, etc... Good to be back! :cool:
  13. ribald1
    There are advantages to getting the wrenching out of the way before the car is painted.
    A little slip when installing an engine can leave a nasty scratch.
  14. PonyExpressRider
    OH MY! It has been in the works, but the car is headed for body and paint, most likely in the next couple of weeks. I am excited.
  15. PonyExpressRider
    Started doing some research on the car... a couple weeks ago I sent out the first 10 letters to State DMV's, to determine how many R codes are still registered. I received my first reply back, from Washington State. Based on the search for the letter R in the 5th position of the VIN, for 1969 Ranchero's.
    The search in Washington State reveled no cars met the search criteria. Why is that interesting you ask??? That's where my car was originally sold new! :)
  16. PonyExpressRider
    Tranny is in the Tranny shop...
    Engine is at the Machine shop...
    once the body shop gets a Camaro out of the way, the body will be going to body and paint.
    Question though... The oil sump that was on the engine was a middle sump... it had holes in it from when the rods exploded... The Ford Manual shows a front sump. Any idea's as to what 428CJ's came with? I need to order a new one.
  17. PonyExpressRider
    While doing some WEB searching, ran across Muscle Car of the Week. They have two Ranchero's that are Notable. A 1957, which is really Rare, 1 of 2, and both owned by the same collection. And a 1969, which is 1 of 3 R codes in the Brittany Blue. I have one of the other two.
    1957 Ranchero
    1969 Ranchero
  18. PonyExpressRider
    Update...
    Body Shop about ready for the Body.
    Prepping parts and pieces for reassembly.
  19. Vasili Brown
    Vasili Brown In Third Gear
    Charlotte and Wilmington NC
    Looking good. Can't wait to see it after paint
  20. PonyExpressRider
    a small parts dilemma... The car came with a Master Cylinder Mount, which raises the booster and master cylinder a few inches to clear the Exhaust manifolds. The pivot point has a grease fitting, and two rubber seals on either side... Tried Ford, Bob Drake, Early Ford Store, Dearborn Classic, CJ Pony... Any Ideas on where I can get new ones? See arrows in Pic... Thanks
    Vasili Brown likes this.
