The holy grail lol guess what's missing besides the lenses. Someone must have pilfered those parts over the years.
Well, the lenses come off the backing because the glue they used back then aged. I've had to reglue both of Babe's lenses, and one still attempted to come off after I glued it.
Mark i have this 77 for parts cheap , look and see if anything you need / BLINKERS ARE GONE SORRY , SO ARE THE MIRRORS https://ocala.craigslist.org/pts/6706542873.html
The key to posting pictures is that they have to be less then 1MB, jpeg seems to work best... I use Publisher, but any editing software will work...
Thanks for the info, I only use my phone I don't even have a computer anymore lol. Maybe I will try it on the wife's laptop
So today I was going to try and drive it but found out that the brakes don't work. No leaks and the master cylinder is full but the pedal goes to the floor and won't pump up. Ordered a new master cylinder. Then while it was idling the bypass hose blew and made a lovely mess. Went ahead and changed all the hoses. Looks like this project will keep me busy for a while Mark
Looks like one I nearly got back in '08, when my boss moved the shop; the location we moved to had a Ranchero in back that the customer more or less abandoned, so it ended up getting impounded. I was sooooo bummed.
You gotta get these! https://www.ebay.com/itm/4-SPINNERS...AOSwaGBbeZR1:rk:5:pf:1&vxp=mtr&frcectupt=true
Nice, I have been giving the wheels some thought. The spokes are rusted and a few are bent. I don't know if I should stick with them or find someone else. I like the idea of old school 60s on the back and 70s for the front. Mark
They might not even be the right ones, but there just aren't enough Rancheros with wires & spinners on the road!
Ok the weirdest thing happened. I put the new master cylinder on and the brakes work fine, I tried driving it and it wouldn't move. When I checked the transmission fluid it was empty. Before I even bid on it I checked and it was full and looked clean. 4 quarts added now it drives but still is not showing on the stick. No leaks that I can see, I need to pick up more fluid used all I had. Mark
They topped it off before it went through the auction. I had a customer who burned up a trans because it leaked off, immediately took it for a trip to Eastern WA after the purchase. My guess was a leak at the cooler lines or on the pan itself. But her brother did check the trans before she bid on it, and it was full at that time.
It was a trucking company auction that sold out. I talked to the owner he said the car was his and had been sitting for over 10 years. Anything's possible but I see no leaks. There were no keys so the auction co didn't mess with it either Mark
The tranny was likely filled when not running. Once started the fluid all pumped into the convertor, then the pump ran dry. Trannys hold a lot of fluid.
The way I resize pics using my iPhone is to send the image I want to use to myself via email. I select medium size before sending, then save the emailed image for use as the uploaded image to this site.
Welcome in lots of good information in here all you have to do is type, and occasionally put on a seat belt and have a since of humor.
