New member, David Briggs Daphne Alabama 1966 Ranchero
Discussion in 'New Member Welcome Center' started by David C Briggs, May 17, 2024.
  1. David C Briggs
    David C Briggs In First Gear
    Daphne Alabama
    Hello, I am new here and this is my first Ranchero though I have built many cars and had at least 200, most of them cool cars.
    This car has been painted and a 4 link rear and a Heidst Mustang II front crossmember installed w/ mounts welded in for a mod motor,
    The person who started this project is deceased and the car has been kicking around for several years and as a result lots of parts are missing and I hope people on this forum will be able to help.
    I have a 2017 Gen II Coyote and 6 speed, there is lots of room in the front so I am using the rad/fans/condenser from a 21 GT
    For some unknown reason the trans tunnel and firewall were butchered so I was able to get that part from the S550 and am installing that, the rear trans mount, shifter and drive shaft all attach to this so I have the engine on the front mounts and the tunnel bolted to trans mount so everything will be spaced correctly,
    The engine came with a nice set of SS headers and down pipes and is complete, it came with all the harness, ecu and throttle pedal but I plan on using the Ford Stand Alone system.
    The car has a 4 link rear but for some unknown reason they put all of this work into a 7.5 rear axle from a 94 V6 Mustang with 2.73 gear,
    I could fix this mess but have decided to go w the entire rear suspension from another GT with the 3.73 ratio, this should be pretty cool.
    I will post some pics an soon as I can figure out how to do it.
    Buds 67 and andrewok1 like this.
  2. Dyno
    Dyno In Overdrive
    Ridgely, MD
    Welcome.
    Sounds like a heck of a project, though has some nice stuff in it already.
    Good luck and post the pics.
  3. rollachristoph
    rollachristoph In First Gear
    Las Vegas, NV
    Hello & Welcome. I also have a 66 Ranchero, base model, that I rescued from a field in Oregon last year. My largest issue was replacing the entire front suspension, & some minor engine work on the 347 V8 that the 2nd owner put in it.
    Seems You have your work cut out for you. Pics would be great!
  4. David C Briggs
    Daphne Alabama
    It is a pretty good project, the biggest part of it will be welding in the fire wall and the floors, tomorrow I am pulling the engine and trans back out so I can start the sheet metal part of the project.
    Buds 67 likes this.
  5. 1978GT
    Welcome, and good luck with your Ranchero project!
    At least 200 cars? Yowza!
  6. andrewok1
    Welcome to the site
  7. Buds 67
    Buds 67 In Fourth Gear
    Rome, Georgia
    You have come to the "right site" for Ranchero knowledge David from Daphne, Alabama! I had a good friend that lived there for over 20 years before he passed away a year and a half ago. Mike Mann was his name, Anyway good luck on your Ranchero project!!! & WDE!!!!!!!!!!!
  8. Saff54
    Welcome to the site david
