no fuel coming out of tank.
Discussion in 'General Ranchero Help' started by FordR500GT, Nov 4, 2017.
  1. FordR500GT
    El Paso, TX
    The tank is half full, but when I went to pull the fuel line off the bottom of the tank, it immediately sucked tons of air into the tank and no gas dripped out. Opened the gas cap, still now flow. Vent problem? Pickup tube clogged?
  2. ribald1
    Vent problem for sure.
    The anti-siphon loop prevents gas from coming out when the cap comes off.
    The pick up is not blocked, or air would not have rushed in.
  3. FordR500GT
    El Paso, TX
    How should I go about chasing the issue? I'm gonna pull out the sending unit and clean it up because it isn't working as it should
    Don't mean to be a pain, but;
    How do you know the sending unit isn't working as it should?
    You know you have a vent problem, correcting that needs to be done anyway, so why not fix that?
    Over analyzing a situation is common, however, if rather than heading to the end first one fixes problems as they are encountered, that usually ends up being the quickest and cheapest road to a solution.
  5. FordR500GT
    El Paso, TX
    Sending unit isn't working because it is stuck. I tap the housing, and the gauge reads correct, but if the fuel level changes, it gets stuck again. It's quite annoying, because at first, I thought someone had stolen the gas as the gauge read E, but it wasn't floating up in the tank
  6. ribald1
    Doesn't it correct while driving then? If the issue is that it takes excessive time to read correctly, then the gauge is the problem.
    A sticking sender should resolve after the first bump in the road and can't go below the fuel level and return.
  7. FordR500GT
    El Paso, TX
    Can't drive it yet, so I don't know. Hasnt been on the road since 2015
  8. Huevos
    Sounds like a good idea to pull the tank, put in a new sending unit and sock, new fuel lines and filler hose.
    Not hard to do.
  9. ribald1
    In that case, I would expect it to stick. While fuel is the lubricant for the axle it operates on, fuel becomes sticky varnish when left exposed to air for a period of time. Luckily, over a short time, new fuel dissolves the varnish.
    You're vent problem is likely created by a modern cap, as I described earlier, that needs to be drilled.
  10. FordR500GT
    El Paso, TX
    Already redone all of the lines today, installed electric pump,and replaced the fuller hose but can't get fuel to the pump. Tried taking the gas cap off. Nothing. Gas will come out of you blow air into the filler neck, but only then. Last week, I pulled off the fuel line and plenty of gas came out, but now anir only goes in.
  11. ribald1
    You misspoke, right?
    The fuel line is at the top of the tank.
    I think he's referring to the outlet line, which on the '72-'79 is at the lower left side, below the fill.
  13. FordR500GT
    El Paso, TX
    Yep (I think that is where the electric pump should be hooked to?) Anyway, I got the tank out early this morning. Heard my fair share of sand floating in there. Pulled out sending unit and everything else. I'm currently waiting for the inside of the tank to evaporate whatever gas/rusty gunk that will evaporate, then I will clean it out with some acetone and a pressure washing (Maybe put a stainless steel chain inside and slide it around to break up the rust?)
  14. FordR500GT
    El Paso, TX
    2017-11-05-12-29-45.jpg 2017-11-05-12-28-58.jpg 2017-11-05-12-28-50.jpg 2017-11-05-12-30-17.jpg 2017-11-05-12-29-56.jpg
    Put a borescope cam inside the tank. Here's what it got
  15. Huevos
  16. 1965 Ranchero 66G
    What year is it ? You have multiple, If it was mentioned I missed it.
  17. LSChero
    Yikes!Hope thats caked on sludge,not rust pits.Tanks available 74-79,a little larger but will fit in 72.Was the pick up tube filter intact?
    This is what mine looked like.
  18. CJ Guy
    CJ Guy In Maximum Overdrive
    Space, The final Frontier
    You do remember you have a rebuilt tank I had for the GT.
  19. handy_andy_cv64
  20. FordR500GT
    El Paso, TX
    It's a 72
