Noob in SoCal with '64 Ranchero
Discussion in 'New Member Welcome Center' started by colnago, Oct 16, 2018.
  1. colnago
    colnago In Overdrive
    Ridgecrest, CA
    All,
    I finally took the plunge this weekend, and picked up a 1964-1/2 Falcon Ranchero. The registration lists it as a '64, but there are definite features that are '65 (289 engine, 5-lug hubs, front grill). The PO did a great job on the body/interior, but it's having some mechanical issues that any normal 50-year-old vehicle has. This weekend will be a rebuild on the Autolite 2100 carb (major stumble on acceleration; any gotcha's to look out for on the rebuild?), and checking the timing (she's missing the timing pointer, so I've ordered a replacement from the 'bay). I have a piston stop, so I'll also be confirming the pointer/balancer marks.
    Questions to come as I stumble along. My previous ride was a '67 Ford F250, so at least I'm not afraid to get my hands dirty.
  2. Jeff B
    Welcome Joseph. Lot's of knowledge and good peeps around here. Post up some pics when you can.
  3. beerbelly
    Welcome Joseph, and let me know if you need any info or photos of a '65. I'm retired, and have nothing better to do :)
  4. DJ Clinton
    DJ Clinton In Second Gear GOLD MEMBER
    Mesquite, NV
    From another 64 1/2 owner, welcome!
  5. Mike1969
    Mike1969 In Fourth Gear
    Missouri
    My accelerator pump nozzles were plugged with varnish on my 2100, which made a mean stumble. Cleaned them out with a needle.
  6. colnago
    Ridgecrest, CA
    I checked my accelerator nozzles, and they were clear as could be. I got a very steady stream when I blipped the throttle. I think I had the opposite problem. The arm linkage was on the top hole, so I moved it down two holes. It did great in the driveway, but the real-world test will be the morning commute tomorrow.
    I also think the timing is way off, because I get a vibration when driving. I won't be able to check that until the weekend, though.
    A vibration? DO make sure you physically check the TDC position of #1, and then, does it still have points? If so, make sure you set dwell (24-30*) before you try to set timing, but make sure the balancing ring on the damper has not slipped. If it does, it'll make the engine run with a big vibration, and trying to 'dial in' the timing will make it way too retarded...cause your exhaust manifolds to glow!
  8. PonyExpressRider
    PonyExpressRider In Overdrive
    Welcome Joseph... you will find plenty of help here, sarcasm too, inquiring minds want to see what it looks like!!!
    colnago likes this.
  9. colnago
    Ridgecrest, CA
    Hmmm ... I'll have to see how to decrease the size of my photo. What's the max size on this forum?
    I want to say that the max size is 640X480.
  11. PonyExpressRider
    anything less then 1MB... I use publisher, but any photo editor should work.
    colnago likes this.
  12. colnago
    Ridgecrest, CA
  13. DJ Clinton
    Mesquite, NV
    Someday I hope my ride looks that good.
  14. colnago
    Ridgecrest, CA
    Thanks. She's pretty to look at, and the interior is outstanding, but she runs pretty rough. I'm hoping that on Friday I can find TDC and start checking the timing. By the way, she has a 289 with an Autolite 2100. Is there any good sources of manifold vacuum on the intake? Do I just have to be inventive to find a source?
  15. PonyExpressRider
  16. DJ Clinton
    Mesquite, NV
    Mine is a 289 with a Holly 4 barrel. Mine is in Utah and I'm in Nevada right now, but from what I can remember, vacuum to the distributor is off the base under the carb. There is also a vacuum manifold at the back of the intake manifold.
    The port for dizzy vacuum is in the base on the passenger side, under the front of the choke assembly. I think I have a pic, and will post it if I find it.
  18. handy_andy_cv64
    BTW, I always liked the mid-60's Fords with the Torq-Thrust D's. Made for Corvettes, but best on Fords.
    colnago likes this.
  19. colnago
    Ridgecrest, CA
    The Holleys and Eddys have a port for manifold vacuum. Unfortunately, the Autolite doesn't. I haven't had ten minutes to look at the intake, though, so there might already be something back there. If not, I'll figure something out (like a 4BBL intake and a Holley/Edelbrock carb, or a 2BBL Holley; much more fun than a $5 brass fitting from AutoZone).
    On a positive note, my timer pointer came in today, so Priority 1 tomorrow is to install it and set initial timing.
  20. colnago
    Ridgecrest, CA
    Haha! Just saw the post on the location for ported vacuum. Found that on Day 1. The PO had the dizzy tube going to the passenger-side idle screw! So there was no vacuum advance, and I started out with a vacuum leak! Grrrrr! Fixed that right away.
    Currently, there is a gap between the accel pump plunger and the arm. It's probably 1/8". So, when I accelerate, nothing happens ... other than the engine dieing. Hopefully, I can fix that tomorrow, too, although I may have to chuck the existing carb, and start from scratch.
