Oil pressure drop to zero 79 ranchero
Discussion in 'General Ranchero Help' started by Shawn, Dec 2, 2018.
  1. Shawn
    Shawn In First Gear
    When you start the car the oil pressure goes to its normal position once I put it in gear it drops to zero ive checked the oil and its at the safe/ correct oil level this started happening yesterday it also back fired two times on top of that it also turns off and restarts by its self randomly with out messing with the key ive rebuilt the carb spark plugs and wires I have no idea how to fix it can anybody help me out ? Not even my local shop can pin point the issue
  2. aquartlow
    Check the fusible links at the starter solenoid and/or the accessory stud(if you have GT style gauges), also have a look at the fuse box, could also be an ignition switch issue but that requires a bit more work to get at. Hope this helps.
    I realize this response was directed more toward the electrical issues and not exactly the oil pressure gauge reading, although the gauge is electrically powered thus the reason to check the fusible links.
    rancheromac and ForistellFord like this.
  3. ForistellFord
    Beautiful Foristell Missouri
    Spot on, really. With the myriad of electrical oddities mentioned, that must be sorted before we begin talk of bad mains or a dying oil pump.
  4. Shawn
    Shawn In First Gear
    Thanks ill look into and let you guys know if it worked
  5. LSChero
    Check and clean all your battery connections and grounds at engine and firewall..Shine up connections at starter solenoid.Make sure battery is fully charged with good cables and alternator is putting out 13.5-14.5 volts running.Then go from there..Welcome to site!
    I'd put my money on a worn ignition electrical switch, as I had the same problem in my '89 Bronco (not the same switch part number but the same basic design), but going ahead and checking all your connections underhood, on the right fender well is sound advice anyway, as our rigs are up to 40 or more years old, and they likely will have corrosion or loose connections. Fuse links can be checked with a 12 volt test light, poked in at the switch side of the connection, and the wiring wiggled, looking for a blinking or no light.
  7. plumcolr
    i'd look at the ground straps, either battery lead or engine to chassis, and their attachment points first.
  8. burninbush
    I'll take a shot at this ... beginning by saying that every car should have a mechanical oil pressure gauge, one that doesn't depend on any electricity to tell you your pressure. You can add one with a T-connector to the existing oil sender.
    Assuming it still has pressure, then that won't disappear instantly, so the problem must be electrical. Do you have a dash readout of pressure, or just a light that comes on to say 'no pressure'? If that's the case then the problem is likely the sender unit. Ground the wire leading to the sender, and watch the dash gauge for an effect. If you have a gauge that reads pressure, then it might be the sender, same test for it.
    Car starting itself must be the ignition switch, the one down the column, It might just need adjustment.
    It's also possible you have a connector problem feeding the instrument cluster, a large maybe 14-pin connector that feeds electricity to all the gauges and lights on the cluster. Remove the dash to get to it.
    Start with a real pressure gauge, they aren't very expensive. If it really doesn't have pressure then you'll want to talk to somebody about a rebuild.
    TestDummy and ForistellFord like this.
  9. cbolt
    Palm Coast, FL
    You should be able to hook up a mechanical direct pressure gauge without even installing it, just to see what you actually have oil pressure wise once you put the car in gear. Cheap and easy place to start.
    I'm on the "your problem sounds electrical" bandwagon and could be as simple as a loose positive battery cable or as complicated as a chafed wire somewhere behind the dash. Good luck and let us know what you find.
  10. colnago
    colnago In Overdrive
    Ridgecrest, CA
    Was the backfire through the carb, or through the exhaust? Is it still doing it?
  11. Gregory Cummings
    Oceanside, CA
    what can you tell if the backfire is from the carb or exhaust. I had a backfire sounded like the exhaust backfire. Soon after my valve lifters or some thing in there started ticking and sometimes tapping. Funny thing is it doesnt do it all the time. Also very interesting, my 79 351/400M 2V rattles in the engine only in cold damp weather (figure that one out). she loves the summer but hates the winter i guess.
  12. colnago
    Ridgecrest, CA
    If it's through the carbs, your intake valves aren't closing, or you have burnt intake valves. Or your dizzy is WAY advanced (but if that were the case, you'd probably be pinging/pinking). Some carbs can be damaged by a backfire through the carb (but that's about all I know on that score).
    If it's through the exhaust, then there's gas igniting in the exhaust side. Late timing (real late), burnt exhaust valves (not usual), lean mixture leading to HOT exhaust manifolds), etc.
  13. Dan the ranchero man
    I would look at electrical first before messing with the engine at all. The suggestion given at the beginning of this post will most likely help you find your trouble. Backfiring (in this case) sounds like your ignition is cutting out and then restarting. That will cause a backfire for sure. once that is handled "then" I would see how the car runs. If you still have engine issues then move on to diagnosing engine issues.
  14. colnago
    Ridgecrest, CA
    Dan,
    What would cause the ignition to cut in and out? I've not seen that before.
    Since it likely still has its Duraspark ignition, a weak coil (caused by shorting in the windings when it heats up during charging), a weak pickup coil in the dizzy (caused by a weak magnet) or a worn dizzy bushing and/or shaft, (which causes the reluctor on the shaft to sometimes not be the proper distance from the pole piece in the pickup coil) can cause the ignition to cut out and back in, but usually, the ignition just quits, stopping the engine.
    colnago likes this.
  16. Dan the ranchero man
    All the things Andy said plus Bad grounds (to the engine) faulty ignition switch (internally broken) Duraspark box breaking down. On the box those will just shut the engine off after running a few minutes. Then any number of things can happen after.
    1) engine restarts after a few min
    2)engine starts right up but dies again after about 10 min
    3)engine engine will false start pop & sputter through carb or exhaust but after sitting a while (10 min or so) will restart.
    colnago likes this.
  17. Garbageman
    Garbageman In Overdrive
    SW Washington
    I owned a 71 that would run fine, then every once in a while would shut off while driving down the road. A few seconds it would restart, sometimes backfiring. It took a long time to determine that the coil had a hairline crack it. Once I replaced the damaged coil never had another issue.
    colnago and ForistellFord like this.
  18. plumcolr
    Ditto on the coil. Also the dizzy cap. Look for crack or carbon track on the inside.
  19. handy_andy_cv64
    Carbon tracking will only cause cross-firing, not necessarily backfiring (depends on where the piston is in the four cycles if it misfires to cause a backfire), but should always be inspected and cleaned every 10K anyway.
  20. 1979 RANCHERO GT
    1979 RANCHERO GT In Overdrive
    Back to your original post. My 79 started the same thing with it's oil pressure gauge. A new sender from Ford fixed the oreilly sender problem. Part number E4ZZ-9278-A motorcraft number SW-1547-B.
