Oil pressure instrument light bulb replacement
Discussion in 'Ranchero Tech Help' started by 66Ranchero, Aug 22, 2017.
  1. 66Ranchero
    66Ranchero In Second Gear
    Hey guys!
    I've noticed that my oil pressure light never comes on when I turn the key to "on", but my alternator light does for the bulb check. Is it a difficult job to remove the instrument panel and access that bulb? I have about 7 screws on the front of the panel holding it on. I'd assume you just removes the screws and the panel comes out?
    Thanks!
    -Hayden
    Even on older clusters, the bulb sockets are accessed off the back. Since you'll be back there, you might just want to do all of them, indicator and illumination at the same time.
  3. 5.0 Chero
    first grounding the sensor wire to make sure its not a gummed up sending unit
    That, too. Christ, I'm getting senile.
  5. Freestyle Don
    You`ve got to disconnect the Speedo cable as well. If you want brighter instrument lights, change to LED. Relatively inexpensive.
  6. Sparkes442
    Sparkes442 In Second Gear SILVER MEMBER
    Martinez, CA
    In addition to those 7 screws, you'll have to take off the speedo cable to remove the cluster.
  7. Freestyle Don
    Further to changing to LED`s. Removing the BLUE `diffusing`inserts {plastic things} allows more light to the gauges. I found some red Led`s on eBay.
  8. ribald1
    Don't lose the tubes over the turn signal lamps.
  9. Bryan59EC
    Bryan59EC In Overdrive
    San Antonio, Texas
    You might be able to just reach under the dash to get to it.
    Good call about grounding the sensor wire to double check the unit.
  10. 66Ranchero
    Thanks for the replies! I was able to wiggle my hand up behind the dash and get the bulb out and replace it. I also replaced the ALT bulb since I was back there. Everything lights up as it should. :cool:
    Bryan59EC likes this.
