Overheating.... Sorta
Discussion in 'General Ranchero Help' started by Cullen McTaggart, Aug 10, 2017.
  1. 1965 Ranchero 66G
    Pay or not, what does that have to do with not checking the radiator.
  2. beerbelly
    Huh? I'm not following your train of thought...
  3. ribald1
    Your check is in the mail. There will be a deduction for using 'usually' though.
  4. beerbelly
    Apparently he will be paying me for this, but at a reduced rate...
  5. ribald1
    Actually, I am sending a Coors Light. If your performance improves, so will your compensation.
  6. beerbelly
    Gee, maybe I can attain Budweiser status with enough adoration!
  7. ribald1
    That would be a step down from Colorado Kool-Aid.
  8. 1965 Ranchero 66G
    You hit him in his ego using usually instead of absolutely.
    Hey! Leggo my Ego!
  10. Freestyle Don
    Right OR wrong? Not my intent to disagree with those with different experiences. I suggested checking the radiator. And as I mentioned, it had not been suggested. As a `non` mechanic, that's where I`d start. Of course there are other factors causing over heating.
    1965 Ranchero 66G likes this.
  11. 1965 Ranchero 66G
    You were right, overheating = check the cooling system. You are also right about other contributing factors.
  12. Cullen McTaggart
    Cullen McTaggart In Third Gear SILVER MEMBER
    Coronado California
    Well when I had my road trip adventure 4th of July weekend I threw a push rod into another one I pulled the lifters out and I can't remember for the life of me if I put them back. so I might have destroyed my cam I also am going to have to take a look at my water pump to see if I have any flow that could be a problem, and of course the timing is a huge problem and I know I need a carb tune haha let the money pit adventure start.
  13. Cullen McTaggart
    Coronado California
    Thank you for your suggestioni checked my radiator it seems to be good It was a bit low so I added and it seemed to flow through hasn't been low since that's why I went on to the tstat but I'm open to rechecking that's what this thread is about getting as many trouble shooting possibilities out of the way.
  14. ribald1
    If you didn't put the lifters back in the pushrods would not have been able to be installed and you would have a non running engine.
  15. ribald1
    The reason the radiator wasn't brought up was due to your description of the overheating. If it were overheating at speed, a plugged radiator would be the first thing to check.
  16. 1965 Ranchero 66G
    As much as we might disagree, you saved the blisters on the end of my fingers on that one. Sounds like the party before the deployment so I will give him the benefit of the doubt. Come home safe and whole.
    Skip
  17. Cullen McTaggart
    Coronado California
    No I put the lifters back in but if I put the lifters in the wrong one wouldn't it destroy the cam?
  18. ribald1
    That depends on the condition of the lifters and the cam. It is good practice to keep track of all the parts and reassemble them back in the positions they were originally, unless the cam or lifters were set to fail anyway the only harm would be a shorter cam life, but with hydraulic lifters things are a bit forgiving.
    If a lobe wiped, or a lifter failed you would have cylinders that didn't work. It would be real rough and very little power.
  19. 1965 Ranchero 66G
    Not unless you put them in upside down. Then it would have been cowboys and Indians when the pushrods blew through your valve covers and hood. If, just saying, if you got it together like that... I want to see the video.
