Power to lighter stays on with the key out
Discussion in 'General Ranchero Help' started by dadcohn, Apr 6, 2019.
  1. dadcohn
    dadcohn In First Gear
    Danville, CA
    I plugged a usb charger into the cigarette lighter to charge my phone and when I turned off the beast (64 Ranchero) and took out the key the usb charger stayed on and the phone kept playing. Is it supposed to do that? If not, what could it mean?
  2. Huevos
    Thats so you can light your cigar without turning the ignition on...
  3. 72GTVA
    Yes, that is how they are designed through that period. Handy for lighting up, or using a plug in device available in that era.
  4. dadcohn
    Danville, CA
    Ok I’ll stop worrying but I gave up cigars years ago
  5. 72GTVA
    At least the plug in spot light works, as does that 12V auto vacuum, and there was a 4 track player in a box available sometime in the 60's...
    Saff54 likes this.
  6. colnago
    colnago In Overdrive
    Ridgecrest, CA
    Mine works that way, too. So does my '67 F250. I've never chased down the wiring, but I am "assume-ing" that it's supposed to work that way.
  7. DJ Clinton
    DJ Clinton In Second Gear
    Mesquite, NV
    It is always powered and there is a breaker built in to the back of the lighter socket-no fuse.
    Even into the '80s they were that way. Originally, as 72GTVA mentioned, it was so you could light up with the ignition off, because of the points, but Ford and GM kept that going for a long time after electronic ignition. Hell, my 2000 Century has constant power to the lighter. I have to verify I pulled the charger out before leaving the car.
  9. plumcolr
    Every car I've ever owned was like that - from a '54 ford to a '18 Yukon (OK, the yukon's my wife's. But my old expedition does too).
  10. Doc76251
    Doc76251 In Fourth Gear
    Virginia Beach, VA
    That was always my go to constant hot source before I was old enough to know what a volt meter was or afford it.
    Cheers,
    Doc
