Rear Anti-Sway bar
Discussion in 'General Ranchero Help' started by Dave Reginek, Jul 20, 2024.
  1. Dave Reginek
    Dave Reginek In Second Gear
    Michigan
    I'm looking for help on a rear anti-sway bar installation for my 1972 Ranchero.
  2. pmrphil
    ADDCO sway bars - even though they're aftermarket, might be pics/instructions that help
    Dave Reginek likes this.
  3. Jeff B.
    Anacortes, WA
    I installed an OEM rear anti-sway bar on my 74 years ago. What help are you looking for?
  4. Dave Reginek
    Michigan
    I ordered this... I looked around on line and this is what was recomened for my 72.
    Addco 938 - Addco Performance Anti-Sway Bar Kits
    ACO-K1-938-0U
    Mfr. #: 938
  5. Dave Reginek
    Michigan
    Did you notice a difference after you installed? Could you post a few pic's of how your looks especially where and how you mounted it? Thanks Jeff...
  6. uk ranchero
    uk ranchero In Third Gear
    on mine you would notice the bar underneath the axle. there is a lot less body roll going around corners, i also have a slightly bigger bar on the front. if memory serves
    1 1/8" in place of original 1"
  7. Jeff B.
    Anacortes, WA
  8. Jeff B.
    Anacortes, WA
    I uploaded the 3 images above. The first shows the bar from the rear, the second shows how it attaches to the axle housing with a U-bolt and the third shows how the links on each end attach to the frame cross member near the rear axle.
    I installed the sway bar approximately 14 years ago. I remember thinking it had a positive affect on handling and reducing body roll but can’t quantify it being so long ago.
  9. Dave Reginek
    Michigan
    Jeff... Thank You so much. This really helps. I will installing mine next week. I will let you know how it goes...!!!
  10. Dave Reginek
    Michigan
    I may change the front one too... I'll see how it drives after I put the rear one on... Thanks for you input...!!!
  11. andrewok1
    uk ranchero likes this.
  12. uk ranchero
    just found a picture of mine , however its too large to post. my axle mounting bracket bent so i made a new one by copying a picture of original ford part. is that lower link a Spohn part, i have those as well
    andrewok1 likes this.
  13. andrewok1
    Yes
    SPOHN upper and lower control arms
    Made a wonderful difference no body roll
  14. uk ranchero
    I have to agree with that
  15. andrewok1
    Not to mention the need for Good Shocks on all 4 corners
