Red Ryder
Discussion in 'The Stable' started by LSChero, Jul 10, 2014.
  1. andrewok1
    hey John maybe these guys could help you out
    [​IMG]See photos
    View on Map
    Website
    Directions
    4.8Address: 2714 S Highland Dr, Las Vegas, NV 89109
    Hours:
    Open today ยท Phone: (702) 733-6216
    Website: http://www.countskustoms.com/
    Category: Auto Restoration Service
  2. Shok
    Shok In Third Gear
    salinas, california
    If the money is an issue I would not go that deep into the motor for what is basically an inspection. Maybe do a compression or even better a leak down test for starters. You can always pull one or two caps out of the bottom end to get a look at he bearings.
  3. LSChero
    In order to swap this 5.0 into the 72 oil pan and timing cover have to be removed.Iam replacing heads and upper and lower intakes with upgraded units.
    At this point ill remove pistons and crank.Thinking with glass half full,all will be good.Have plenty time,money not so much.
    IF crank and bore are within specs I will reinstall with new bearings after clean up.Wont really know till I mic parts. Heads will eat up most of budget.
  4. andrewok1
    so hows the shop coming long ? getting everything in place is a fun thing, well it was for me , i have a 5.0 harness and computer here if it would be of any help to you ,
    I love your lawn around the shop !!!! but must be hell on the mower blades :D:D:eek:
    His mower's a 1948 Cat D4. Has a Navy "Seabees" mark on it....
    andrewok1 likes this.
  6. andrewok1
    hey i would love to see a picture of that
  7. LSChero
    Shop is WIP,got a couple more shelves installed but still can decide on layout.Got to fit the queen(73) inside and all my tools and crap.
    Trying to finish main house before heat gets here.Match exterior color to garage,3 more interior rooms to paint,new floors and carpet...
    Come along way in a few months,almost there.Will be glad to have grease in my nails again.Fook a bunch of paint!
    Rocks SAM_3400.JPG SAM_3645.JPG are cool,grow real slow and water once a year with roundup!
  8. LSChero
    At last,all major new house projects are done.Started gathering parts for 5.0 mass air swap this winter.Found one of my stang main harness looms but no injector/O2 pigtails.Does anyone know if donor injector/O2 harness off MK7 SD compatible with mass air main harness?Blk and wht conectors look to be same.
  9. 5.0 Chero
    Yes its the same as long as your MK SD is an Ho Roller and it should be
  10. LSChero
    Yes,HO.Ill pin out before installing.Still need fuel pump harness/relay/inertia switch from EEC if you come across one.Very few foxs in yards here.
    Do I need to install AIR idler or can I route new belt from pump to alternator?(if I can find correct length)Using OE brackets/hardware with AC.
  11. 5.0 Chero
    Gated belt K060845 6 rib 84.5 inches long
  12. andrewok1
    i have a harness from a 1990 302 mustang ,its complete ,injector /rear /inertia switch, o2 / would this be any use to you John
  13. LSChero
    Thanks Carl!Amazon had one for cheap.
    Got a spare main harness,but thank you for offer Andy.Thinking I should be able to get fuel pump wires/switches off most ford EFI cars of same vintage at the yard.Just got to get off my butt,root around see what will work.
  14. 5.0 Chero
    Least I could do since I have failed on getting you any of the parts from your list to you. I been busy with the surgery recovery, job hunt and now starting a new job
  15. ribald1
    No more funemployment for you.
    All good things have to come to an end sometime.
  16. 5.0 Chero
    Actually did not bother with unemployment
    non working time was only 2 weeks and I had 3 jobs to chose from. Was looking for work wile on SDI Was on SDI for Surgery most of the time off do not think 900 or so bucks is worth the hassle...
  17. ribald1
    At only 2 weeks, by the time you qualified it was over anyway.
  18. LSChero
    Good to hear you recovered fully and found new employer.Whats the new gig?
  19. 5.0 Chero
    Soup Kitchen..........
  20. ribald1
    Workin in a wreaking yard?
