Red Ryder
Discussion in 'The Stable' started by LSChero, Jul 10, 2014.
  1. handy_andy_cv64
    Ah, Nevr-Dull, the bane of any sailor's existence. Does it come with a can of elbow grease?:confused:
    Doc76251 and Hillbilly like this.
  2. LSChero
    Front half together,carpet in,DRL in new grill,front and rear cameras as well.Havent figured out where to plumb left a/c vent,may just go away with Intellitronix gauge cluster install..Pulled the trigger on new Ron Francis EFI harness,tired of screwing with 30 year old cooked harness.
    SAM_4953.JPG SAM_4954.JPG SAM_4956.JPG SAM_4957.JPG SAM_4959.JPG SAM_4960.JPG
    HuevosRanchero and Buds 67 like this.
    And how much was the Ron Francis harness? Does he use the same wire color coding as Ford factory did?
  4. LSChero
    627.00 all in.Havent look at it yet Andy.Each wire is printed description to function.No emission systems,of road use only..HA!
  5. Hillbilly
    You might check out some of the Vintage Air dash ducts or maybe some billet ducts used in street rods.
  6. beerbelly
    And grille bars match hood scoop bars-nice!
    LSChero likes this.
    I don't want "off-road use only," I plan to have the emissions all intact. Will he build the harness with the emissions gear in mind?
  8. LSChero
    Bought a vent off a G6,little bigger than I wanted but may work.Problem will be finding place to tie in flex duct.May have to tap center ducts,
    they are close.Cant go straight back,defroster duct in way..Ill fool with it Hillbilly till I get frustrated.Actually center pair blows pretty good with
    left vent capped,but I like cold air directly on my noggin..
  9. LSChero
    Check out "painless" harness kits Andy.
  11. Hillbilly
    You might find a small rectangle shaped duct that would go in under the left two gauges. If not, maybe under the climate control and light switch.
    Oh, so a bat 'n' ball cooler, instead of a noggin cooler?
  13. Hillbilly
    Multi purpose depending on where you aim it.
    handy_andy_cv64 likes this.
  14. LSChero
    Cluster in bezel,majority wires terminated except EFI connections.Old cooked harness out,found broken pin at harness O2 connector.Hopefully EEC will
    work properly now..
    Buds 67 likes this.
  15. Doc76251
    Doc76251 In Fourth Gear
    Virginia Beach, VA
    Seems I've seen a similar bit of aluminum used to rebuild a dash somewhere before ;)
    Cheers,
    Doc
  16. LSChero
    Doors on today,still need to install glass and adjust to get them to seal better.Took her to town today filled up with 91 swill.Runs like a completely different engine.Even feel the computer adjusting mixture as it learns.Very pleased with new harness! Off to the window tint guy next week.
  17. LSChero
    Everyone enjoy your forth of July celebrations,be safe!
    Kiwirancher and beerbelly like this.
  18. beerbelly
    Nice! You need to find parade to show off that car.
  19. Garbageman
    Garbageman In Overdrive
    SW Washington
    Nothing sweeter than when a super ride comes together. Very nice!
  20. LSChero
    Thanks for props guys,but she aint all that.Better than pealing hoochie mama moroon.Ill enter the next used tractor show when it comes to town.
    Been a while since the girls stayed in the same roost!
    Buds 67 likes this.
