regular or premium gas in chero.
Discussion in 'General Ranchero Help' started by Gregory Cummings, Apr 9, 2019.
  1. Gregory Cummings
    Oceanside, CA
    The book says use premium in the 351 modified. Can I use regular gas in the 351/400M. I saw a show where you can use premium or regular gas because the new cars regulate the stoicometric (spelling) 14.7:1 fuel mixture. Gas here in so cal is 4/gallon.
  2. TestDummy
    You can run what you want, until it starts knocking. I doubt your engine has compression over 8.5:1, so you could probably run 83 octane.
  3. pmrphil
    The most likely reason for premium was the issue with detonation (pinging) even though the compression was well BELOW 8 to 1. Combustion chamber design (or lack thereof) made the "M" series engines knock like all get out. The only fix was higher octane. You could pull timing out, but they're already kinda doggy and that would make it even worse.
  4. PonyExpressRider
    PonyExpressRider In Overdrive
    $4 a gallon? GEESH! I pay $4.50 for 93 octane (non-ethanol). And they pump it for me! 106 octane (non-ethanol) is about $8 a gallon. As much as I am tempted to see what would happen, I just can't do it.
  5. colnago
    colnago In Overdrive
    Ridgecrest, CA
    Well, $4/gal was last week! And what do you mean that they pump it for you? I thought Oregon just changed that law, so you could pump it yourself.
    Some people like to pay for the service of getting pumped, I mean, having their gas pumped ;)
    colnago and PonyExpressRider like this.
  7. PonyExpressRider
    They did change it for less populated rural areas. Like Lake View, you pump yourself after 6PM. Gas stations on the I5 corridor, still have station attendants. From what I have seen, some may allow you to pump it... but the price is the same!
  8. Gregory Cummings
    Oceanside, CA
  9. Gregory Cummings
    Oceanside, CA
    You must life in Hawaii or LA.
  10. PonyExpressRider
    Paid $4.57 for ethanol free 93 octane yesterday... at a Shell station no less! Saw an article that says prices in CA are up to $4.70 for regular... didn't say where though.
  11. colnago
    Ridgecrest, CA
    I just paid $3.959 for 87 octane this morning at the cheap station (SoCal high desert area). It's usually a little cheaper here than in the cities, though.
  12. Doc76251
    Doc76251 In Fourth Gear
    Virginia Beach, VA
    I paid $2.58 for regular at WaWa this morning, pumped it myself. All you non pump your own types need to learn how to pump gas. I left out of NJ with my 77 T-Bird in 1985 heading to CT for Sub School, needed gas when I got there, after sitting in my car for 10 min then getting out I realized I had no idea how to operate the damn pump, I turned it off and on so many times trying to figure out the correct sequence that the gas station guy finally came out and showed me. Young dude, hot car and I was very humbled.
    Cheers,
    Doc
