Remove the AC
Discussion in 'General Ranchero Help' started by Parker Harger, Oct 13, 2017.
  1. Parker Harger
    Parker Harger In Second Gear
    Boise Idaho
    So I have removed the AC parts including the plenum from my 72 Ranchero. The question is, does anyone know of a heater only cover for that?
    andrewok1 likes this.
  2. burninbush
    Well ... one person here used an old valve cover as a duct. Not sure what it was from, but it seems like an easy fix.
  3. andrewok1
    they are differant ,heat only to A/C ,NO COVER ,you will need to make something
    I cut the original cover down and fiberglassed over the opening.
  5. Parker Harger
    Boise Idaho
    That's a good idea. I know they make them for GM - http://www.acdelete.com/
    Just thought someone might know one for ford.
  6. andrewok1
    [​IMG][​IMG]thanks rabald1 , the gm and ford cover is the same
  7. Parker Harger
    Boise Idaho
    Yeah, that is the website. But those looks to be only or GM models. Is there a model that is similar to the Ford 1972?
  8. LSChero
    Search the web Parker,find pic of ac delete fire wall to get some ideas.Maybe John will post pic of his mod.,seems simple.
    Nows the time to replace bean can,rag joint if you havent already.I installed rebuilt steering box,with tilt steering wheel.Steering nice and tight now!
  9. Parker Harger
    Boise Idaho
    I like the idea of cutting down and modifying the original AC box
    Still looking for a vacuum reservoir “can”
  10. Parker Harger
    Boise Idaho
    On the 72 the heater hoses are on the right. And no round area to the left
    These do look sweet though.
  11. andrewok1
    you could run you heater hoses to the right side,just a couple 3/4 holes , i used this in place of vacum can
    • [​IMG]
    Click to open expanded view
    Dorman
    Dorman HELP! 47076 Vacuum Tank Unit
    31 customer reviews
    Price: $12.05 & FREE Shipping
    Ships from and sold by Amazon.com.
    • Dorman Vacuum Reservoir 47076
    See more product details
    Compare with similar items
    New (29) from $10.20 & FREE shipping.
    Report incorrect product information.
  12. Parker Harger
    Boise Idaho
    Thank you sir. I will pick that up
  13. Parker Harger
    Boise Idaho
    So here is my AC box. The bottom holes are broken out and its in need of some repair. I guess I will take all the parts out and see if i can turn it into a better box by cutting it down a bit.
  14. Parker Harger
    Boise Idaho
  15. Parker Harger
    Boise Idaho
    Parts removed and broken in half. We have a boat/fiberglass repair shop here locally. I will see what they think about making it smaller.
  16. Der Flieger
    Der Flieger In Third Gear SILVER MEMBER
    Arvada,CO
  17. Der Flieger
    Arvada,CO
    That didn't work try this :
  18. Parker Harger
    Boise Idaho
    ok, that makes sense. thanks man
