replace spark plugs 1974 ranchero
Discussion in 'General Ranchero Help' started by Mel13nunn, Mar 12, 2018.
  1. Mel13nunn
    Mel13nunn In First Gear
    I'm having a hard time replacing the spark plugs on my 17 ranchero 500 with Cleveland engine. Any help appreciated.
    What's the difficulty you're having?
  3. ribald1
    Use a spark plug socket, they are not regular sockets; you can spot them by the rubber insert inside, and turn them out counterclockwise. They may be a bit stiff.
  4. burninbush
    Do what Ribald says; seriously, use the correct socket. The right socket type will also make replacing them easier. I'd just add that a flexible socket drive handle (has a vertical joint near the socket) can make getting to it easier.
  5. Eri Schwein
    Eri Schwein In First Gear
    I replaced mine when I updated my headers. If you take off the exhaust manifolds, it's very easy to get to the plugs. If you don't have a spark plug socket, put a little electrical tape on the inside of the socket.
  6. 1965 Ranchero 66G
    Spark plug socket is much cheaper than exhaust manifold gaskets and and a whole lot easier. Lol
    FordR500GT likes this.
  7. Steve 74gtQ
    Steve 74gtQ In Overdrive
    Medford Oregon
    Why take manifold off are you changing them from the bottom. ford-cleveland-tech-351-two-barrel-illustration.jpg
    1965 Ranchero 66G likes this.
  8. ribald1
    Back in the 90's my wife fell in love with a Chevy minivan, so I got it for her.
    Had it less than a year, one of the spark plugs could only be changed from underneath with your arm snaked up against the firewall, doing the job by brail one handed.
  9. Steve 74gtQ
    Medford Oregon
    If plugs are stuck soak with good penetrateing oil like PB blaster.
    Wd40 is not a good penetrateing oil.
    Warm up motor a little before soaking not smoking hot. 2 mins is fine. If you can get to turn a little respray and re tighten then work back and forth. This will work the oil down the threads after awhile they will come out.
  10. Steve 74gtQ
    Medford Oregon
    Oh yes lots of engines are that way.
    But not the cleveland they are in the open. Just junked in place I'm sure
  11. beerbelly
    I seem to remember my Dad having a big-motor LTD or Torino in the 70's, and I believe you had to loosen one of the motor mounts to get to a plug or two; does that sound familiar?
  12. Steve 74gtQ
    Medford Oregon
    The windsor motor does have plugs hid by the exhaust so that could be possible.
    Most ford V8 engines have plugs above the exhaust manifold
  13. ribald1
    The Windsor has the exhaust manifold below the plugs, like the Cleveland.
  14. Steve 74gtQ
    Medford Oregon
    Guess I remembered wrong lol
  15. ribald1
    There is a Ford engine that came with a manifold that went over the plugs, but it is an old school one that is eluding me at the moment.
