Restoring old auto glass?
Discussion in 'General Automotive Questions' started by Tygr1, Nov 8, 2018.
  1. Tygr1
    Tygr1 In Fourth Gear SILVER MEMBER
    My side and back glass has water stains, surface scratches and just a film of some kind. You know what I mean...46 year old neglected glass.
    So does anyone have a DIY way of semi-restoring this glass to at least make it shine again?
  2. Jeff B
    Might try white vinegar on water stains followed by a good glass cleaner and newspaper (not paper towels) and some elbow grease. You cold try to find a glass polish, some people like Bar Keepers Friend, for light surface scratches, but a scratch that can catch your fingernail is not likely coming out.
    Hillbilly likes this.
  3. ribald1
    Clean the glass thoroughly. Then slide a razor blade across the glass (held near flat to the glass) to lift out any embedded dirt.
    Take 0000 steel wool and polish the glass.
    If that doesn't yield satisfactory results you will need to get glass polishing kit and practice on some scrap glass with it first.
    Kiwirancher and Hillbilly like this.
  4. Tygr1
    Thanks kids. So there is hope. You guys are great.
    andrewok1 likes this.
  5. TestDummy
    I clean my windshield with 0000 steel wool and Rain-X at least annually.
    andrewok1, Kiwirancher and Hillbilly like this.
  6. CJ Guy
    CJ Guy In Maximum Overdrive
    Space, The final Frontier
    Every once in awhile you get the right answer, 0000 steel wool.
  7. cbolt
    Palm Coast, FL
    I don't like rain-x products on my windows. Shortens the life of the wiper blades, or so I have heard. I do use the steel wool and normally glass perfect, or just plain old windex, whichever is closer to the steel wool when I decide to clean windows. Everyone has a different opinion when it comes to products for glass, and lots of folks swear by rain-x, my wife being one of them. For awhile there I was making my own stuff out of alcohol and vinegar. Cheap and works well in washer systems.
    There are glass polishing products out there and I would love to know if anyone has tried them and whether or not they have had success restoring old glass.
  8. andrewok1
    cbolt likes this.
  9. plumcolr
    Yeah, the cerium oxide works, but requires care. And it is extremely toxic if inhaled or ingested.
    I found a very small amount of dishwashing liquid (like a eighth of a ounce or less) in a gallon of cheap washer fluid (alcohol mix) makes a big difference in how good it works in nasty conditions, like slushy dirt.
    cbolt likes this.
  10. ribald1
    I have a power polishing pad and compound for glass. Care has to be taken with it's use as a windshield is two rather thin pieces of glass with a compound in between to create the anti-shatter. There isn't much that can be polished away without the windshield becoming fragile.
    cbolt likes this.
  11. Tygr1
    I have a new windshield. It's just the sides and rear that have that haze to them.
  12. TestDummy
    Like always?
  13. Huevos
