Scored some GT40P heads for my 289
Discussion in 'Ranchero Tech Help' started by Ian Goolsby, Oct 3, 2018.
Tags:
  1. Ian Goolsby
    Ian Goolsby In Second Gear
    I just got a great deal on some very fresh Scored some GT40P heads for my 289. My 289 is stock but i did upgrade to a edelbrock performer intake and avs2 500 cfm carb. Also has long tube headers which i really will hope work with the new heads. I guess my question is has anyone used this and what was your experience. Thanks for the input.
  2. pmrphil
    Headers for the "P" heads are not the same as "regular" heads - the plug is in a different location, so normal headers "cover" the plug hole. They will bolt on, but you can't put plugs in them - won't run well that way. :(
  3. zerolash
    zerolash In Third Gear
    I got the same heads. I went with a flange ffrom Advance Auto and long tubes and it fits fine no issues with plugs or wires.
  4. pmrphil
    What kind of flange - an adapter flange? Or are they headers made to fit the "P" series heads?
