Serpentine belt drive for a 400
Discussion in 'Ranchero Tech Reference & Articles' started by Robbtroy, Feb 14, 2016.
  1. pmrphil
    Is that a Price Motorsports kit under the intake?
  2. Robbtroy
    Robbtroy In Second Gear
    San Angelo, Texas
    Why yes it is, the best way to get 'er done. Bill and Mary have a great product and service.
  3. pmrphil
    Absolutely. I've been using their stuff since 1987. Miracle workers.
  4. Robbtroy
    San Angelo, Texas
    A quick update, dropped the brackets off to be powder coated. They should be back in a few days. Decided to go with a utility type of gray.
    I can't wait to see it set up.
  7. Robbtroy
    San Angelo, Texas
    Well, closing in on the finish line,. Waiting for the harmonic balancer to be shipped back from being rebuilt.
  8. Robbtroy
    San Angelo, Texas
    Ahh, looks great. When the balancer's on, which crank pulley are you using, and does it require modification to fit the hub?
  10. Robbtroy
    San Angelo, Texas
    The crank pulley is a standard off of a 5.8L , I pulled it out of the local wrecking yard and it also matches the one on my '95 E-350. No modifications were necessary. All of the holes lined up perfectly.
  11. ribald1
    A big issue with the Windsor block is timing cover alignment.
    Bolting the cover down without the balancer in place and the oil pan loose can create a situation where the seal is torn when the balancer is installed, no matter how careful you are.
  12. Robbtroy
    San Angelo, Texas
  13. Robbtroy
    San Angelo, Texas
    One of The good things about the 400's (351M's) was the locating pins for the timing cover plate, pretty much dead on every time.
    Fortunately I've not had any issues with the seals. (replaced the oil pump and bearings back in the early 90's on Her in order to get some oil pressure back) did the front and rear seal at the time.
    She now has a one piece rear seal as an update. uses the same one as the 5.8L.
  14. handy_andy_cv64
    I thought there might've been some overlap on parts between these engines. That"s good to know.
  15. Robbtroy
    San Angelo, Texas
    Had to machine the back of the block to accept the one piece rear seal, but that's about it on the crank.
  16. handy_andy_cv64
    That's good to know.
  17. Robbtroy
    San Angelo, Texas
    Well, I received my harmonic balancer back from the Damper Dr. They do excellent work. Dropped the engine and transmission in.... IMG_20170504_200854.jpg
  18. Robbtroy
    San Angelo, Texas
    Did a quick spin test..... On the starter only,. Everything is running true, so far........
  19. pmrphil
    Only the early ones - the later ones have dowels to locate the cover, same as 5.0 blocks.
  20. ribald1
    I haven't seen a small block Windsor with locating dowels, then again I don't work with the mouse engines much, my late 80's 5.0 HO doesn't have them, and the 69 block it replaced didn't have them.
