Source for Manifold Vacuum?
Discussion in 'Ranchero Tech Help' started by colnago, Feb 4, 2019.
  1. colnago
    colnago In Third Gear
    Ridgecrest, CA
    Stupid question time. I want to use a vacuum gauge to tune the carb and timing. But my Autolite 2100 only has a timed vacuum source. No biggie, I can use the port under the carb where the PCV goes. Man, that sucker is huge! :eek: No, none of my adapters neck down from huge to small. So, is there an adapter I can get from AutoZone? Is there another port I could/should use? Tranny port, maybe? No brake booster.
  2. PonyExpressRider
    PonyExpressRider In Overdrive
    looks like you should have vacuum port on the back of the intake... looks like timing vacuum coming from back there
      File size:
      231.2 KB
      7
  3. pmrphil
    tranny port will work just fine
  4. Doc76251
    Doc76251 In Third Gear
    Virginia Beach, VA
    I'm gun shy as hell about anything coming from the trany as I had trany fluid in all my vacuum lines due to a blown vacuum modulator. On my 77 I have a tree on the fire wall that I plugged into for a permanently mounted vacuum gauge. That said I also took Beerbellies idea and plumbed my trany vacuum line into my main vacuum line so if that modulator blows again it won't get everywhere. To do that I went to Advance Auto and they have an assortment pack of reducing tees in the "Dorman Help!" section. $4.98 for the pack to get the 3/8 - 1/4 - 3/8 reducing T. Now I have lots of T's but cant find my pack of vacuum caps:(
    Cheers,
    Doc
    I went to redo the vacuum on mine, and I had the opposite problem...caps out my ears but any Ts that could work? I might as well invent a time machine to go back to the '90s and get what I needed from there.
