Spark plug wires hidden
Discussion in 'General Ranchero Help' started by Ran Man, Jan 21, 2020.
  1. Ran Man
    Ran Man In Third Gear
    Does anyone have a picture of their spark plug wires rerouted in order to show off the motor? I am looking for ideas if you have suggestions or pictures
  2. TestDummy
    With a front mounted distributor (Ford), it's not easy hiding them. I suppose you could make them go down in front of the engine and up between the exhaust ports. Lot of work. I bought a roll or wire from MSD, the terminal ends, the crimper tool and some clamps. Looks better than most Ford engines with spaghetti wires.
    Ran Man, beerbelly and HuevosRanchero like this.
  3. beerbelly
    These look pretty slick:
  4. Ran Man
    Beer belly those look great. I am trying to get mine done for show season
  5. Ran Man
    I like this set up. Did you do them yourself? What type of separators are those?
  6. beerbelly
  7. Dyno
    Dyno In Third Gear
    Croydon, Pa
    Summit or jegs sells wire looms, used a set on a 351W years ago. They are a universal fit but help clean up the look as shown above. Don't have any pics handy.
    I use zippy ties simply because I'm having to be cheap. But I feel that the look a Ford V-block engine should have the wires straight from the cap across the valve covers. That's just me.
  9. LSChero
  10. Ran Man
    That's how mine are and I used zip ties also.
  11. TestDummy
    Good question. I found them at a garage sale. I think they were industrial something or another. I had to clamp them together and drill each hole big enough for the wire. I did make the wires. Cut to length, and add the ends. MSD sells them that way.
    Freestyle Don likes this.
