Steering Issues
Discussion in 'General Ranchero Help' started by rollachristoph, Jul 4, 2024.
  1. rollachristoph
    rollachristoph In First Gear
    Las Vegas, NV
    Having replaced practically the entire front end/ suspension system, I am still at a loss as to why the steering on my '66 Ranchero just feels loose as all-get-out. I've already replaced tie rods, sway bar, upper/ lower control arms & bushings, Pitman arm, front end alignment, power steering pump,etc. The only thing I havent messed with so far is the steering gearbox.
    I've been told they are adjustable, but I dont see how. When I get above 65 mph, it's like steering control disappears, & it wants to drift.
    Any other possible suggestions/ solutions I should explore, before I go on the hunt for a new steering gearbox???
  2. Clark
    What about a rag joint? Does the '66 have one. Rag joint failure is typical.
  3. Kiwirancher
    Kiwirancher In Fourth Gear
    Gisborne , New Zealand .
    No rag joint in a 66 if it has the original box . When I got mine I removed the steering box and had a friend ( mechanic ) look at . It needed new bearings - one was collapsed. Made a big difference . The only adjustment is with the screw ( bolt ? ) and locknut on top of the box but be careful not to tighten it too much , you could do more harm than good .
    Denis.
  4. Parker Harger
    Parker Harger In Second Gear
    Boise Idaho
    I got a new steering gearbox from Redhead. Mine is a 72 but it made all the difference. I had so much play in it.
  5. rollachristoph
    Las Vegas, NV
    Thanks for the input, Gentlemen. Seeing as it's the original steering gearbox, I'll have to ask around to find an old-school mechanic to rebuild it.
  6. Kiwirancher
    Lot of fun taking it out - managed to do it without removing the radiator but found it best to remove the seat !
    Denis.
  7. RANCHEROROB
    Pueblo de Los Angeles, Aztlan
    If your box is shot and you have manual steering you should look into a Borgeson power steering set up.
    It's not cheap but worth the price if you have a nice car and MUCH Safer that original box.
  8. rollachristoph
    Las Vegas, NV
    Vehicle has original power steering; I'll look into Redhead steering boxes for compatibility; Bigger issue at the moment, is getting a custom-built aluminum radiator/ cooling fans, nothing aftermarket matches up with the dimensions! :mad:
