Stock distributor vacuum advance can
Discussion in 'Ranchero Tech Help' started by Jeff B, Sep 29, 2025.
  1. Jeff B
    On my 70 Ranchero with a stock 302 the vacuum advance device is falling apart. This one has 2 vacuum ports, but I am wondering if I can replace that one with a single port device. The distributor works and has a Pertronix module in it, so if I don't have to replace it, that would save the Ranchero bucks for other things.
  2. burninbush
    Your car is too old to require smog checks -- so get the single one-pipe connection advance unit. I suggest that you connect it directly to manifold vacuum, but the ported vac connection works too.
  3. Jeff B
    Thank you very much.
