Stupid me... I just bought a Chevy!
Discussion in 'General Automotive Questions' started by FordR500GT, Dec 13, 2017.
  1. ribald1
    I guess that is one way to sneak Ford castings into a GM production line.:p
    Oh, yeah, I forgot about the Poncho.
  3. pmrphil
    We all try to. :rolleyes:
  4. Bryan59EC
    Bryan59EC In Overdrive
    San Antonio, Texas
    For some general GM wiring practices
    Red---generally direct battery power and may not be fused
    Orange--is generally a fused line to the battery-----dome lights and accessories that are powered all the time
    White----generally a switched ground path----dome lights----------also feeds turn switch from brake switch
    Pink---hot with key on and related to items that operate with ignition
    Brown---Accessory separate buss that is also energized with the key in "Run"
    Not sure if this will help you, but these are kinda the suggestions I go by when working on GM
  5. Bryan59EC
    San Antonio, Texas
    This had me questioning myself when I was doing some distributor work on a friend's GTO----I think DeLorean was stoned.
    Considering your DeLorean rebate came by the kilo, I'm inclined to agree.
  7. FordR500GT
    El Paso, TX
    Might as well bring this up again.. Spent a fair amount of money to get the Blazer as a DD, but as of now, it runs nearly perfect (besides the bad valve seats making it smoke)
    I'd rather be using the blue '72 as a DD but that will take a lot more work yet.
  8. 1965 Ranchero 66G
    You mean bad valve guides ?, does it smoke all the time or just on deceleration ? Chevy made hats to go over the valve stem between the head and rocker, other than that try Lucas.
  9. TestDummy
    STP can slow that smoking down.
  10. FordR500GT
    El Paso, TX
    Smokes all the time. Especially at low rpms.
  11. FordR500GT
    El Paso, TX
    I'll try that
  12. 1965 Ranchero 66G
    Lucas, the better and improved STP.
  13. ribald1
    Valve guides or rings.
    Pull a plug, soot means rings, paste means guides.
    If it's the guides, replacing the stem seals will help a lot.
  14. FordR500GT
    El Paso, TX
    I doubt it's the rings because there's no blow by.
  15. ribald1
    Failed oil rings and failed compression rings often occur together, but not always.
