Sweaty Betty.
Discussion in 'The Stable' started by ccain, Oct 23, 2016.
  1. Bryan59EC
    Bryan59EC In Overdrive
    San Antonio, Texas
    Might consider wiring in a set of headlight relays---easy to do and you will have some brighter lamps
    the wiring in any production vehicle is marginal at best, and age, corrosion and a number of other things can wipe out the wiring in a hurry.
    Now---if the brake switch does not fix the brake lights---you may need to change the turn switch.
    Ya--I know--turns and hazards work----big deal
    every time you activate a signal, you deactivate the brake circuit for that side
    Turn switch has 3 different sources of power
    Brake switch power------only powered with the pedal depressed
    Accessory power-----Turn signals
    Battery power----hazards.
    If that brake contact set in the turns is freaking out---no brake lights.
    I can't really give you colors to check as my lil Ford has been wired with GM colors and functions----(do what you know)
  2. ccain
    ccain In Third Gear GOLD MEMBER
    Well THERE's yer problem!!!
    Found the issue with Betty's brake lights. The wire and the plug must have had some irreconcilable differences and decided to separate. :(:oops:
    It's hardest on the children. :D
  3. Basstrix
    Perhaps it was coincident that it happened after the welding?
    Glad you found the problem.
    ccain likes this.
  4. ccain
    Thanks!
    Hell, god knows when the wire broke. I could have been driving with no brake lights long before the welding.
    I do know that the brake lights worked the last time I did a light inspection on the car...
    Well, okay, the wife said they were working... I think she may be trying to kill me for the insurance money. You know... "Double indemnity" and what not. :eek::D
  5. Steve 74gtQ
    Steve 74gtQ In Overdrive
    Medford Oregon
    Old age and treachery lol
    ccain likes this.
    Yeah, pattern failure. The wife is always looking for a bit of cash to...I mean...those pesky wires always break....
  7. Lowrider
    Lowrider In Third Gear
    Kingman AZ.
    Common failure on all Fords with that plug. Replaced many over the years. One of the 1st places you looked when the brake lights went out.
    ccain likes this.
  8. Hillbilly
    Those wires were too short in the beginning and often routed incorrectly causing a pull on the connector every time you pushed the brake. Common sense while you repair the broken off wire tells you to lengthen the leads to prevent this nonsense from happening again. Glad you found it !
    ccain likes this.
